Thread: 06 pontiac GXP CV Half Shaft Replacement
Results 1 to 7 of 7
  1. #1 06 pontiac GXP CV Half Shaft Replacement
    I live here. DirtDog's Avatar
    Jun 2012
    So i noticed that my CV half shaft was leaking transmission fluid very slowly today while investigating another noise coming from my passenger side wheel...and it just turned out to be sway bar link ends bad. But I have never had to replace a cv shaft before and It sounded very simple from what the guy at auto zone told me. I was wondering if anyone has a write up or knows how to do it and can post it on here for me. I have looked on here alot and cant find an actual write up on how to replace.
  2. #2 Re: 06 pontiac GXP CV Half Shaft Replacement
    Passenger side?
    If so thats the trans diff case/outer trans seal or whatever the hell its called. You still have to pull the axle to change it.
    Here you go. http://www.grandprixforums.net/how-r...xle-39805.html
  3. #3 Re: 06 pontiac GXP CV Half Shaft Replacement
    Jun 2012
    Well I had the dealership look at it and they were the ones who said it was a bad cv half shaft. And the boot on the CVS is spraying grease on everything on the passenger side. But if the trans diff case/outer trans seal is what's leaking the transmission fluid where is it located and how hard to replace is it. I have no experience working on the cv so its gonna be a new job for me
  4. #4 Re: 06 pontiac GXP CV Half Shaft Replacement
    The seal is right on the end of the diff housing, you cant miss it.
    You'd have to pull/pry it out and tap the new one carefully, then replace with a new axle.
  5. #5 Re: 06 pontiac GXP CV Half Shaft Replacement
    Jun 2012
    Advanced auto parts and auto zone both do not carry that seal. Do u know where I can go to online or somewhere to get one
  6. #6 Re: 06 pontiac GXP CV Half Shaft Replacement
    Napa # NOS 13750 A/Trsax Seal, Output Shaft - Right
    I've bought one from there and didnt have any problems with it.
    Or you can buy them from the dealership.
  7. #7 Re: 06 pontiac GXP CV Half Shaft Replacement
    Jun 2012
    the dealership charges freaking stupid high prices on everything. but ill check that out i think theres a napa store about 30 minutes away. But over all i dont think this is going to be to hard of a job for me to do. Im also replacing the sway bar end links and the tie rod ends while ive got it all apart for that shaft
  1. half shaft / tranny question - looking at a car to buy
    By EternalX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2012, 07:30 AM
  2. stock ride height correct half shaft question
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 06-15-2012, 01:13 AM
  3. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  4. half shaft cause abs/tcs light?
    By LAIDBACKLUKE in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2010, 08:17 AM
