Thread: Throttle body leaks coolant. Need advice!
Results 1 to 4 of 4
  1. #1 Throttle body leaks coolant. Need advice!
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    So I took off the throttle body last night to clean it up and saw that it had a gasket. I didnt even really consider what was behind it and I should have. The gasket itself looked good yet so I figured I would just reuse it because I had no good way to go to town to get another and it was late anyway. I put it all back together and went and started the car and the coolant would start leaking out after about 7 seconds. I guess I was kind of surprised to see that and at the same time bummed because that meant that today I had to bike 6 miles to my college. Should I just look into another gasket or is there something I forgot to do? Also if I need a gasket would any parts store have one?
    Not sure if this was already asked around here but I dont have internet at my place and I dont really have time to search around due to classes and such. Thanks in advance to anyone who can help!
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Throttle body leaks coolant. Need advice!
    Here's the part numbers for the gasket. I assume you have a L36..but listed both
    61024..............Throttle Body gasket (L67)......................
    61093..............Throttle Body gasket (L36)........................
  3. #3 Re: Throttle body leaks coolant. Need advice!
    Thanks for the part numbers! And yes it is the L36. Sorry for not stating that.
  4. #4 Re: Throttle body leaks coolant. Need advice!
    Just a quick little update,
    All it was was a gasket problem and its been running good for a full day now and not leaking at all!
  1. Coolant leak from Throttle body
    By jakegsxr11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2022, 07:48 AM
  2. PLEASE HELP: Coolant leaked out when removing throttle body
    By RideWithPride in forum General Tech Discussion
    Last Post: 07-29-2012, 02:10 PM
  3. Throttle Body Spacer/Coolant Flow
    By TeeWX in forum General Tech Discussion
    Last Post: 03-26-2010, 12:38 PM
  4. need advice with installing a throttle body spacer
    By Real Ricer in forum How To Write-Ups/Tech Tips
    Last Post: 11-19-2009, 09:05 PM
  5. i make wa baypass for the coolant to the throttle body opinions
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2008, 11:22 PM
