Thread: Any Suggestions on brake lights
Results 1 to 6 of 6
  1. #1 Any Suggestions on brake lights
    GT Level Member Hamm61's Avatar
    Aug 2008
    Illinois
    Two days ago I noticed that one of brake lights was out. Today I go to replace the bulb only to find out that both of my brake lights were out. I go to take the bulbs out and they look perfectly fine and not blown out at all. I put them back in and do some test and low and behold they light up when the lights on the car are on (not the daytime running lamps) however whenever I press on the brake I get nothing. Another weird thing is that the light in the rear windshield responds perfectly fine with braking, lights on, ect.
    So now I try to figure out where the problem might be. Since the light in the rear windshield works fine and the bulbs are not burned out I immediately think fuse. I go through and check the fuse and it is working fine, not burnt out. I'm really starting to scratch my head now. So I go through all of the fuses (and I'm including the ones under the hood as well) and find out that all of them work and none are burnt out.....
    What now? I scheduled an appointment at my local mechanic because my father and I can't figure it out and we spent over 4 hours looking with no result. ANY SUGGESTIONS WOULD BE GREAT especially before I take it to the mechanic.
  2. #2 Re: Any Suggestions on brake lights
    Barksdale AFB, LA
    Did you ever actually put a new bulb in? There are two filaments in the bulbs... One for when the parking lights are on and both come on regardless when you brake.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Any Suggestions on brake lights
    Aug 2008
    Illinois
    yes, i actually put in a bulb from my dad's grand prix that we both knew worked and the bulb or bulbs did the exact same as mine. I also put my bulbs in my dad's tail lights and they worked fine so I am still drawing a blank....
  4. #4 Re: Any Suggestions on brake lights
    Barksdale AFB, LA
    I'm about to hit the sack. If you can wait until tomorrow maybe I'll remember to look at some wiring diagrams and try to see what the problem could be...
  5. #5 Re: Any Suggestions on brake lights
    Oklahoma
    Brake switch perhaps?
  6. #6 Re: Any Suggestions on brake lights
    Aug 2008
    Illinois
    Thanks Saberwings I appreciate it.
  1. Mod Suggestions For Beginers
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-26-2008, 01:51 AM
  2. Tire Suggestions
    By Risinnfallen in forum General Tech Discussion
    Last Post: 05-27-2008, 04:11 PM
  3. Muffler suggestions
    By DanGTP in forum General Tech Discussion
    Last Post: 03-29-2008, 11:34 PM
  4. MOD suggestions please
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 07:59 PM
  5. Buying a TV. Suggestions?
    By thermanlee in forum Off Topic Discussion
    Last Post: 01-15-2008, 03:56 AM
