Thread: Cat gasket
Results 1 to 17 of 17
  1. #1 Cat gasket
    SE Level Member 99gtprix's Avatar
    Aug 2012
    Bay City MI
    Going to change the exhaust gasket on my gt tomorrow, its the one at the front of the cat. Has anyone ever done this? Tips? Thanks
  2. #2 Re: Cat gasket
    So where the downpipe bolts to the rear manifold?
    If so, its going to be a pain, well most of the time it is, the bolts may snap.
  3. #3 Re: Cat gasket
    Aug 2012
    Bay City MI
    Right at the front of the cat. My buddy told me about the bolts, I bought new ones already to switch them out.
    1999 Grand Prix GT N/A (at the moment )
  4. #4 Re: Cat gasket
    Front being where?
    The front of the cat is welded on the pipe and has no gasket near it untill the flange where it bolts to the manifold.
    The rear of the cat is very close to the rear catback flange where they is a gasket.
    Here is a ZZP downpipe.
  5. #5 Re: Cat gasket
    Aug 2012
    Bay City MI
    the gasket thats ahead of the cat, closest to it. My buddy is a state cert mechanic and looked at it and showed me what to buy. Id take a pic but its too dark out
  6. #6 Re: Cat gasket
    Those bolts snap on you guys? I've never had an issue with them snapping. A few stubborn ones, but never a snap.
  7. #7 Re: Cat gasket
    My godly like man powers are too much for the bolts and snap.
  8. #8 Re: Cat gasket
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by 99gtprix View Post
    Heat, lots of it. if no head PB Blast, lots of it.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  9. #9 Re: Cat gasket
    You guys..
    I don't soak these bolts, don't heat them up (they are in exhaust anyhow) and never have much trouble. Maybe it's the angle etc you are going at them ?
  10. #10 Re: Cat gasket
    Apr 2012
    Middletown DE
    You guys..
    I never have an issue getting them off, but I am always on a lift, could be they are on the ground.
    1993 Oldmobile 88
  11. #11 Re: Cat gasket
    I'm on the ground. Once had one on Bonne that didn't want to play nice. Bought 6 point box wrenches and used part of my jack handle as a rod then beat the piss out of it with the bigger hammer. Finally got it.
  12. #12 Re: Cat gasket
    Denver
    I replaced my cat, from below, and was STUNNED when the 15 year old bolts spun right off with a 3/8" extension and 6 point socket. I was expecting to be down there with a grinder or torch - they came right off for me - no cheater bar or hammers etc.
    Granted, I live in Denver which is very dry and does not use salt on the roads during the winter.
  13. #13 Re: Cat gasket
    Aug 2012
    Bay City MI
    I didnt feel like battling the bolts because im selling after winter, so I just smeared red RTV around it, will avoid me getting fix it tickets.
  14. #14 Re: Cat gasket
    Because a smear of rubber outside something blowing pressure is going to help?
  15. #15 Re: Cat gasket
    Denver
    That's kind of what Iw as going to say too - now it's going to be leaky and messy.
  16. #16 Re: Cat gasket
    i cant stop thinking hes talking about the cat to res gasket, not the dp to manifold. that would be closest to the cat.
    and if thats the case, just buy 2 new nuts and bolts, try to unbolt them if they break who cares or if they strip the heads off cut the old ones off, the gasket costs 8 bucks and your done. bolts and nuts $1 at the hardware store. could be a $10 fix.....
  17. #17 Re: Cat gasket
    Aug 2012
    Bay City MI
    Well its been a week, been driving a lot every day and its still fine.
  1. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  2. DP gasket keeps going out
    By Sandman in forum General Tech Discussion
    Last Post: 03-18-2012, 01:22 PM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM gasket
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-11-2011, 03:45 PM
  5. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
