Thread: Starting Problems
Results 1 to 15 of 15
  1. #1 Starting Problems
    Aug 2012
    First post, and... I'm sure some of you have heard this before because from what research I've done it's a fairly common issue. Though I haven't found a particular fix.
    Anyways... my 05 Base Grand Prix has a problem. Every time I get in, and try to start it, it dies right away. I have to give it some gas to keep it from dying, or.. try it a second time. The second time almost always stays running. Same thing if I try to use the remote start. The first time, it dies right away. So on and so forth.
    Any suggestions/knowledge?
  2. #2 Re: Starting Problems
    GrandPrix Junkie
    St. Louis
    Remove and clean the entire throttle body. Clean the MAF with approved MAF cleaner. Clean up the IAC (idle air control) as well. Reinstall and call it good.
    Also, when was the last tune-up done?
  3. #3 Re: Starting Problems
    Aug 2012
    Will do.
    And I've owned it since March of this year, it's currently at 101k, and to my knowledge... never. I need to change the plugs and plug wires asap.
  4. #4 Re: Starting Problems
    GrandPrix Junkie
    St. Louis
    Just grab some lifetime warranty wires from any parts store, and some stock irridium plugs. Gap to .060. Should be pre-gapped but double check them all.
  5. #5 Re: Starting Problems
    Aug 2012
    Changed the spark plugs/wires/air filter and my MPG dropped at LEAST 2-3. ? lol
  6. #6 Re: Starting Problems
    Aug 2012
    Cleaned the throttle body, fixed the issue. Thing was disgusting. Lol
    Now I just gotta figure out how to restore my lost power and get my fuel economy out of the toilet.
  7. #7 Re: Starting Problems
    got the plug wires on right?
  8. #8 Re: Starting Problems
    Aug 2012
    Yah. They're on correctly.
  9. #9 Re: Starting Problems
    what plugs did you get?
  10. #10 Re: Starting Problems
    Aug 2012
    AC Delco Iridiums. Same with the wires.
  11. #11 Re: Starting Problems
    do the fuel filter yet?
    it does seem odd that your mpg went down, does it feel like its running better? faster stronger?
    maybe your getting on it a bit more now that it feels good/better?
  12. #12 Re: Starting Problems
    Aug 2012
    Fuel filter is in the tank, yes?
    and yeah the power increased slightly, but no i still drive like a grandma.
  13. #13 Re: Starting Problems
    you should have a in line filter, by the drivers side back wheel area under the car.
    there is a filter in the gas tank. but its really just a sock to keep large stuff out of the pump.
  14. #14 Re: Starting Problems
    Aug 2012
    I can't really see anything, and none of the parts store in my area have anything listed in stock so I assume I don't :/ lol
  15. #15 Re: Starting Problems
    its possible.
  1. Starting problems
    By SCGTP in forum General Tech Discussion
    Last Post: 06-19-2011, 01:18 AM
  2. Starting problems
    Last Post: 06-18-2011, 09:43 PM
  3. Starting problems.... please help
    By gtmgooser in forum General Tech Discussion
    Last Post: 12-23-2009, 10:22 PM
  4. Starting Problems
    By cheever in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-12-2009, 02:55 AM
  5. 04 gt starting problems
    By borst24 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 10:10 PM
