So I have now finished replacing valve cover gaskets, lim gasket, and oil pan gasket over the last couple weeks. I think I still have a leak. The valve cover and lim gaskets were done about 10 days ago. I only wiped down the top part of the heads by the valve covers, I didn't get to clean the full back side of the engine after doing them. The car hasn't been driven more than 15 minutes since then.
Last night I got the oil pan and gasket back on and replaced hoping that that would be the end of the leaks. I just got out there and I have some oil on the floor, under the backside. I checked the valve covers, and they look clean and dry right under them. The oil definitely appears to be coming from higher than the oil pan. So I'm wondering if there is anywhere else the leak could possibly be coming from other than the head gasket?
The gaskets were all leaking for quite some time, so a good bit accumulated on the back of the engine. How long would it possibly be dripping oil for? I'm thinking it would need to have a steady source, but I'm really hoping for something other than head gaskets here.
After I get the subframe back on tonight and can get it into the driveway I'm going to get under there with some degreaser, and try to wash it all off. Hopefully it will all go away, and my problems will be done, but I'm not counting on it.
