Thread: Service ABS System / Service Traction System / Service Stability System Errors
Results 1 to 15 of 15
  1. #1 Service ABS System / Service Traction System / Service Stability System Errors
    SE Level Member Walleyealx's Avatar
    Oct 2011
    Michigan
    I've found a lot of info on this error but nothing for my specific situation. Got back from a trip to Chicago and after filling up the tank I turned the car on and all of these errors popped up. I looked up what the probable cause was and ordered two front hub assembly's that my mechanic was going to put in for me. He scanned it and said the error was "EBCM" so he didn't replace the hubs. Is it still possible that the hubs are the problem, or does that error pretty much confirm that I need to replace or repair the EBCM? The car is a 2006 GP GXP.
    Any help or input is much appreciated. Thanks
  2. #2 Re: Service ABS System / Service Traction System / Service Stability System Errors
    London Ont, Canada
    i get those errors whenever i hook up a Speedo that didnt come in the car lol .. Wonder if anyone can figure that out..
  3. #3 Re: Service ABS System / Service Traction System / Service Stability System Errors
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Post the DTC number(s), if possible.
  4. #4 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Oct 2011
    Michigan
    Quote Originally Posted by Tony Mendez View Post
    If that's something from the scanner I don't have access to them right now.
  5. #5 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Yes, thats what you would need to read DTC's.
    EBCM errors arent super common, buts its possible your took a dump, I believe module masters can repair it for a decent price a very good waranty, if that ends up being your problem.
  6. #6 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Yoga city
    also been told ebcm could be issue on my car also, but then again would it throw a u code cause it cant connect or what?
  7. #7 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Oct 2011
    Michigan
    Well I've got my EBCM out and I will be shipping it in the morning. I have no idea why the instructions tell you to remove the "wave springs" but I will be calling them in the morning to see.
  8. #8 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Sep 2012
    Middleton, ID
    Quote Originally Posted by Walleyealx View Post
    Who did you end up sending it to? How fast was your turn around??
    Thanks
    Gary
  9. #9 Re: Service ABS System / Service Traction System / Service Stability System Errors
    London Ont, Canada
    what are you doing to the EBCM?
  10. #10 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Oct 2011
    Michigan
    I'm getting it repaired. I figured if that's what the error was getting the EBCM repaired is a cheap way to start troubleshooting.
  11. #11 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Oct 2011
    Michigan
    Put the repaired ABS module in and all the errors are gone !
  12. #12 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Yoga city
    this is bothering me cause i had the brake light go off and was only getting a tracition light, i have a u code with ebcm, might be worth to send it out. where did you send your? cost? and did you drive around with the ebcm off?
  13. #13 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Oct 2011
    Michigan
    Quote Originally Posted by Jteske88 View Post
    I sent mine to CheapABS. It was around $115 including return shipping. I drove without the ECBM with no problems. It was about a week turn-around on labor day weekend.
  14. #14 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Sep 2012
    Arkansas
    So how is It now? Still getting codes after being rebuilt? I ask because I have same year GXP as well and I'm having same problem
  15. #15 Re: Service ABS System / Service Traction System / Service Stability System Errors
    Oct 2011
    Michigan
    Quote Originally Posted by Kelben B Watson View Post
    Codes went away right after installation. Still working with no problems.
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. 2004 Grand Prix GT. Service ABS System, and Taction Control System
    By Erika Schultz in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 05:26 PM
  3. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  4. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  5. reduce engine power / service traction system
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 06:56 PM
