Thread: Vibration when under high torque
Results 1 to 7 of 7
  1. #1 Vibration when under high torque
    SE Level Member Special K's Avatar
    Aug 2012
    Western NC
    Just like the title im getting a vibration when my car hits torque peak rpms. A friend thinks its bad transmission bearing. Im thinking that my motor mounts are shot. I need new bushings and the mount look twisted almost. But it doesnt seem to do it as bad when i manual shift which points to the tranny
  2. #2 Re: Vibration when under high torque
    Sounds like your car hates the way you drive it.
  3. #3 Re: Vibration when under high torque
    Aug 2012
    Western NC
    I dont drive my car hard. Not much anyway
  4. #4 Re: Vibration when under high torque
    replace your mounts and get back to us.
    You need to fix all known prblems first before you starting guessing at parts that might not even be bad.
  5. #5 Re: Vibration when under high torque
    Aug 2012
    Western NC
    I have poly bushings ordered for the mounts but i dont have to be on it that hard to feel it.
  6. #6 Re: Vibration when under high torque
    Well for one quit manually shifting it.
    Two, when was the last time it had a pan drop and filter change...NOT a flush.
    Three, go look at the mounts on the engine/trans side...the lower ones. Factory mounts are fluid filled and probably trashed and need replaced. They sell solid rubber lower replacements for cheap. Get some of those. If you haven't flipped the upper dog bones or installed poly's then do that too.
    Then get back at me.
  7. #7 Re: Vibration when under high torque
    Aug 2012
    Western NC
    OK will do. Thanks
  1. Does a 98 GTP have high or low end torque?
    By tigers40 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2012, 06:35 AM
  2. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  3. 04 gt vibration
    By foytz14 in forum General Tech Discussion
    Last Post: 01-11-2012, 03:54 PM
  4. High Stall Torque Converter
    By SMOKIN GTP in forum General Tech Discussion
    Last Post: 05-05-2010, 10:45 AM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
