Thread: Can't remove passenger axle
Results 1 to 13 of 13
  1. #1 Can't remove passenger axle
    May 2008
    I'm trying to get a passenger side axle out of my 2000 GTP, and it just will not release. I'm not keeping tension on it. I have a pry bar with the hooked end sort of hanging on the axle since the straight part can't get purchase anywhere. I have pushed, I have kicked. I'm about to go golfing with a sledgehammer.
    Maybe I'm underestimating the amount of force needed, but I'm shaking the car pretty good. Is there something I'm possibly missing, or some special secret here?
    Thanks,
    Steve
  2. #2 Re: Can't remove passenger axle
    Florida
    I've always had a hard time getting the passenger axle out of the GTP. Take's a very sharp, fast pop to get it to release. I usually use a straight pry bar (no curve at all) and a sledge hammer. I get the end of the pry bar on the inner CV joint, then 1 good whack with the sledge will pop it out. This way, instead of prying, you are using a direct force. Though it is a pain to crawl under the drivers side to do it.
    So basically looking from the front of the car
    -----[ ]_______*insert sledge hammer here*
    Gotta get the bar under the tranny which is a little tricky, but it's worked everytime.
  3. #3 Re: Can't remove passenger axle
    May 2008
    I ended up going the way you described with a steel pipe lever for an old jack I had and the sledge. Took a couple tries, mostly getting the hammer balanced right, but it's done. Thanks for the suggestion.
  4. #4 Re: Can't remove passenger axle
    GT Level Member glendayle's Avatar
    Salt Lake City
    Sometimes I can just pop it out, and other times I can't seem to get it. I always go rent the slide hammer and attachment from Autozone now. Makes popping that CV out easy as pie.
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  5. #5 Re: Can't remove passenger axle
    unless the joint comes apart.
  6. #6 Re: Can't remove passenger axle
    Denver
    Strangeley enough I've found the passenger side to be easier. I just pull from the cup, straight out, with a jerk. I've never needed a pry (unlike the driver's side).
  7. #7 Re: Can't remove passenger axle
    I have a driver side stuck in the trans in my garage right now.
  8. #8 Re: Can't remove passenger axle
    They key to an axle is sometimes to push the axle in first. This gives the compression clip a running start to compressing when you hit it with that quick jab. If it's expanded against the edge and you jab it..you will fight much harder.
    Passenger side, I always crawl under. It's so fast..there's no issue of crawling.. did it as a baby..I can still do it.
    Driverside. Gearwrench 82248, don't question it..don't look at the price, some tools are simply priceless.
  9. #9 Re: Can't remove passenger axle
    Denver
    That's a very good point and great tip.
    When you're pulling the axle, you're compressing a c-clip. If it's flush against the groove, friction will tend to hold it open.
  10. #10 Re: Can't remove passenger axle
    Pennsylvania, USA
    Bill, you make a very good point, that's the same trick I figured out recently when putting in a new passenger side CV axle, I pressed it in tight, got the pry bar in place and supported to ensure it wouldn't slip out, and gave it a firm (firm, not hard) kick with my foot and it popped right out
    I actually found putting it back in to be more difficult until I put a block of wood under the axle to ensure it was aligned perfectly.
    I also had a joint come apart on my old axle, that was DISGUSTING :P
  11. #11 Re: Can't remove passenger axle
    May 2008
    Yeah, I tried every configuration I could think of between turning left or right, having the axle all the way in, and having it gently out all the way. It just wouldn't give with the pry bar and foot pop. Luckily the straight pipe plus sledge from the driver side got it out first shot.
  12. #12 Re: Can't remove passenger axle
    If I suggest something..there's a reason. Cause it works well. =0)
  13. #13 Re: Can't remove passenger axle
    Apr 2009
    Fort Worth TX
    This is another one of those things that pisses me off to no end.
    If the c-clip used on the axle has sharp edges it get's caught when trying to remove.
    I always take the c-clip off and file the outside edges round before install...makes it super easy to remove.
  1. How to: Remove an axle
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 07-29-2022, 09:34 PM
  2. passenger side axle seal
    By hitnf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2012, 11:28 PM
  3. Passenger side (right) axle seal
    By SJAndrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-05-2012, 01:53 PM
  4. Axle passenger side.
    By VGPGT in forum General Tech Discussion
    Last Post: 01-31-2012, 09:44 AM
  5. Will a passenger cv axle from gtp work on a gt
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 12-30-2010, 10:48 PM
