so my idle vacuum and ltfts are all back in order after my header installation but im having an issue getting a misfire and ses code for it anytime I open the throttle up enough that the supercharger would kick on
was told its probably just a tuning issue with the flo mods I added was also told 3 and 5 tend to run the leanest so if I'm running lean thats where the problem would normally present itself .
Just wanted to see if any damage could occur driving it before getting it tuned so long as im easy on the gas ?
and to confirm its most likely a tuning problem caused by either the massive flow increase or the colder plugs
mods to date
t-stat 180 , SD headers , EGR delete , Cat+resonator Delete , Intake , tr6 ngk Plugs(-1heat range)
