Thread: W-body store GTP head or ZZP SS kit?
Results 1 to 4 of 4
  1. #1 W-body store GTP head or ZZP SS kit?
    Jersey
    Just trying to get some ideas...I know a bunch of you guys are Top Swapped Im trying to figure out which kit is a better setup since i really cant afford the cartuning turbo kit . Either way i want to boost my car. I was reading about the ZZP kit and, and it seems they mod the s/c to fit onto the L36 head, im guessing it would make it harder to get a ported gen 5 blower on my L36. Also noticed it would be a bit more pricey to go with a setup like the W-body store. Wondering if i should just go and find the parts myself from a junkyard, or Ed Morrad, or classified's and just build my own kit with the Gen 5blower. How did some of you go about this? Also trying to figure out what tranny mods i would need to support all the added power? Should i expect to spit some gears with my stock trans as is?
    16' wrx sti- stock
  2. #2 Re: W-body store GTP head or ZZP SS kit?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Build your own kit. Take your time, buy my heads, and you'll save a lot of money
  3. #3 Re: W-body store GTP head or ZZP SS kit?
    Hoffman/Schaumburg, IL
    ^^^ X2, but do a lot of research, there is a lot of changes to make a top swap work right... It was 3 months after I put the M90 on that I first got to put the belt on (without endangering the internal engine)
  4. #4 Re: W-body store GTP head or ZZP SS kit?
    Barksdale AFB, LA
    Ed Morad sells all the top swap parts you need for $700. The ZZP kit is the most expensive when all is said and done, but the top swap is a more difficult install. Choose your poison.
    2009 Subaru Impreza WRX STI
  1. W-body store exposed.
    By TDCRacing in forum Off Topic Discussion
    Last Post: 09-16-2008, 12:26 AM
  2. Major loss to the G-body/W-body community
    By Sabrewings in forum Off Topic Discussion
    Last Post: 05-21-2008, 03:47 PM
  3. If you recently bought an aftermarket radiator from ZZP or W-Body store
    By Gandalf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 11:06 AM
  4. GPF store....DONE!!
    By UR LOSN in forum Forum Bugs/Suggestions
    Last Post: 01-01-2008, 02:10 PM
