SO how does one go about bleeding the brakes on a 99 Grand Prix? Becasue pumping them only gets you so far.....
Have someone help you. Start on the rear pass side and have them push the pedal and you open the bleeder. Close the bleeder and have them let up and push again. Repeat as many times as you wish until no air comes out and clean fluid comes out. Then do the same the dr, pf, and df.
or you can use some talent and use the power seats and a 2x4 to push the brake while you bleed....wad up
Rednecking works when you are by yourself.
I pulled out my power bleeder on Friday and there's just nothing like it. Absolutely one of the better tools in the universe.
There are little bleeders on the abs module you could try and bleed those.
Did you start at the rear right wheel and pump it a ton of times, then the rear left, front right and front left? I usually use close to a big bottle of fluid in the process.
If it's mushy..you still have air in the system or a problem with another line.
We never asked why you were bleeding. Soooo why were you bleeding? If you replaced the master cylinder..it takes a bit to clear the lines and have them bleed fully. Especially one brake pump at a time.
I'm pretty spoiled with the bleeder. It's so nice and quick. fluid flows right out and when it stops bubbling etc I let it go a little further to get clean fluid..then done. next wheel etc.
I love it when that happens. I worked on the AC orifice tube, which had me moving the master and abs, apparently the flex lines didn't have enough because a rust spot to the passenger front opened up. Then a middle of the car underneath followed it. Really nice I say.. really fun,.
Yeah I gotta say that these lines are a PITA! Well I'm working on two projects today and so far neither seem to be going my way. First I got the brakes on the gp and then at the same time I'm trying to replace a fuel filter in my Camaro. So hopefully I'll be able to accomplish one or the other lol
Take a moment and do the filter. Shouldn't be too bad.
Then bleed the lines. Overall brake lines aren't tough for me. The tough part is getting into the tight spaces to flare them.
Ha didnt see this in time so I did the brakes first and actually got them all bled out and they work good! Only issue is the front pads are starting to make noise so I get to do those soon. But thanks for all the help! Now tomorrow I get to do that filter and try and seal up the y-pipe along with figuring out the random misfire code on my Intrepid.
Random misfire on 2.7 intrepid? I'd get rid of it.
