Thread: LIM gasket question
Results 1 to 5 of 5
  1. #1 LIM gasket question
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    After i change my lower intake manifold gaskets, ill run my engine for a few minutes, then change my oil. my question is, should i change it yet again a few days/week later, just to make sure ALL the contaminants have been flushed out, or is just that first oil change after the gasket replacement sufficient?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: LIM gasket question
    Do LIM job, drain oil, new oil in, run it 10ish minutes, drain again, new filter and new oil. Thats what you should do.
  3. #3 Re: LIM gasket question
    I do it a hundred miles after with cheapo oil.
    And 100 miles after that with cheapo crap.
    Same deal with the filter too...just use cheap ones.
    Then, go to your normal stuff after about 500 miles total.
    Might be overkill, but better safe than sorry IMO.
  4. #4 Re: LIM gasket question
    Nov 2008
    Fremont Nebraska
    jesus christ that was quick! thanks for the input guys!
  5. #5 Re: LIM gasket question
    My method is this......
    If you don't dump coolant into the lifter valley, then start the car on it's existing oil run for less than 5 minutes. Drain and replace, if the oil was not milky or crappy looking.. happy motoring. If it had anything in it.. run for another 5-10 minutes drain and replace.
  1. GM S/C Gasket Question
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 07:13 AM
  2. lim gasket question
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-21-2012, 05:57 AM
  3. LIM Gasket Question
    By zackp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2012, 07:23 PM
  4. head gasket question
    By BLUESMOKEGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2011, 08:57 AM
  5. 98 L36 LIM gasket question
    By IffyG in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2011, 07:13 PM
