Thread: twin charged?
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 twin charged?
    GT Level Member Ifryrice's Avatar
    Jun 2012
    Osceola, IN
    anyone running a twin charged setup? heard its possible, but a paint, but def wanna do it, just cuz you never see it done....
    "America is all about hot, nasty, bad ass speed" Eleanor Roosevelt 1936
  2. #2 Re: twin charged?
    Many people have done it.
    Your better off picking one or the other (cough cough turbo) and a built trans.
  3. #3 Re: twin charged?
    mi
    ^this
  4. #4 Re: twin charged?
    Jan 2012
    Philadelphia
    im pretty sure the hardest part would be tuning it IMO
    but id just go turbo if you like your GP its probably worth the money
  5. #5 Re: twin charged?
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    yeah go with the turbo. if you do a l67 build you can have both and be "triple-charged" haha. zzp sells a stattama twin turbo kit
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  6. #6 Re: twin charged?
    Jun 2012
    Osceola, IN
    hmmm, but going straight turbo would cost me even more money i think, i mean might as well go twin turbo if im gonna swap heads and intake manifold right? annnd knowing me and my buddies, one of those turbos is going to end up coming off a semi truck.....
  7. #7 Re: twin charged?
    Jan 2012
    Philadelphia
    why would it be more to just turbo?
    it would be more to turbo and s/c
  8. #8 Re: twin charged?
    Jun 2012
    Connecticut
    dude if twin turbo is an option for you just do it lol. i wish i had the money for that.
    2005 Grand Prix GT
  9. #9 Re: twin charged?
    Jun 2012
    Osceola, IN
    a turbo only would require a new intake manifold too... and different heads... and a **** ton of tuning, and i can do most of the fab work for turbo plumbing myself..... saving big bucks over buying a kit
  10. #10 Re: twin charged?
    Jan 2012
    Philadelphia
    you can use your factory intake manifold just get a m90 block of plate there not much
  11. #11 Re: twin charged?
    Cost more?
    Junkyard turbo off a cummins truck, or buy a turbo kit from ZZP or a used one.
    Sell all your supercharged parts and buy a built trans, lots of gauges and your own tuner and be on your way or find a dyno shop thats worth a dam and tune it.
  12. #12 Re: twin charged?
    Jun 2012
    Osceola, IN
    this is all in the planning stages right now, my current concern is the tranny, im a cam install and head porting away from a hand grenade
  13. #13 Re: twin charged?
    Quote Originally Posted by Ifryrice View Post
    Why would you need different heads?
    Upgradeto 1.9 rockers and prolly some 105's or 130 springs.
    But really if you are really even thinking about this, you got days and days if not a few weeks of reading and reseaching about thiese kinds of mods and what is all needed to do this.
    Anytime you mod, its going to require custom tuning.
  14. #14 Re: twin charged?
    Jun 2012
    Osceola, IN
    i didnt think about a block off plate, didnt know you could do that, but i think your flow would be pretty turbulent if you just blocked that **** off? and id get a powerstroke turbo, cummins are actually a smaller engine. and smaller turbo, plus the turbo lag would be really ****ty on a huge turbo, hence why i think twin charging would work out better especially if you have a big ass turbo, blower for low rpms till your throwing out enough back pressure to spool it up
  15. #15 Re: twin charged?
    Again, after all this reading and research you'll figure out which turbo's are the best to use on this size motor.
  16. #16 Re: twin charged?
    Jan 2012
    Philadelphia
    talk to ls1camino about twin charging his GP is twin charged
  17. #17 Re: twin charged?
    Jun 2012
    Osceola, IN
    i realize different turbos are better for different motors, the key factor being the displacement versus the size... too big and you'll take days to spool up, but when you do.... damn..... hence why youd think a twin charged setup would throw down big numbers on the dyno because the SC will give you the boost untill the turbo spools....
  18. #18 Re: twin charged?
    Turbo car with straight rape a twincharged car when done right.
  19. #19 Re: twin charged?
    Texas
    People have gone 11's with a block off plate. You can always use a small shot of nitrous pre turbo to help with spool. I actually plan on doing this.
    85 Corvette
    01 TA
    03 Z06
  20. #20 Re: twin charged?
    new britain, ct
    unless you have a diff blower the eaton will max out pretty quickly on a turbo setup.
    by that time it'll be a restriction rather than a help.
    stock heads will be fine on a turbo build, but porting will def help especially if you get a nice turbo cam.
    yes turbo lag sucks...but at the same time how much power is actually usable in those low rpm's? usually low rpm power translates to wheel spinning. our 3.8's have the capability for a lot of torque as it is.
    07 Black GXP.
  1. GTP SIC ~ Twin Charged (w VIDEO RUNNING pg2)
    By tylerbinski in forum Turbo
    Last Post: 08-09-2011, 11:57 AM
  2. GMR 1" Chain/Gears for Turbo/Twin Charged
    By japslpr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2008, 09:36 AM
  3. Twin Charged Setup
    By japslpr in forum Turbo
    Last Post: 08-22-2008, 05:50 PM
  4. twin charged configuration Stattama Turbo Kit
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2008, 06:01 PM
  5. Trannyman95 twin charged info?
    By ebk231 in forum Off Topic Discussion
    Last Post: 12-17-2007, 04:30 PM
