Can anyone tell me what car this oil pan and motor mount bracket are off of?
2004 GP or a Lucerne with the 3800. Key to that pan is getting that little black bracket with it. If you get a lucerne..there is no bracket so it's part number 10345562 bracket eng mt
I'm laughing at your pics.
Is there a number of any kind on the pan?
Edit: Bill beat me to it. Looks like the pan on my 05 GP. The bolt is right against the tranny pan in that thing for whatever reason. My 04 oil pan is like the 97-03 pans with the bolt on the bottom.
Spade you confuse me man.
I laughed at the pics..cause that's my pan, shelf, bench and kitty litter bucket.
What's the part number on the pan?
And I only need the pickup tube?
The windage tray is part of the pan gasket, right?
There is no pan gasket on an aluminum pan. The windage tray is bolted inside the pan and you use sealant to install it.
Unless someone here has one for sale
Tray should be part of pan. Pan number..I dunno look up an 06 GP to be safe.
You need
Pan (part# 12597244_
Pickup tube (part# 24506437)
Mount bracket (part# 10345562)
Mount (old one should work)
Small tube of GM engine sealant (no gasket on these pans)
If you are a steel subframe most of them have an ear on the side of the bucket that you need to cut. The edge is like an ear that sticks out toward the motor and would hit the pan. The below subframe has the ear cut off.
FYI...Pan Number is 12597244
Thanks a lot for the info guys. Now to start my search and hope I can get everything together before the weekend.
Who has the pickup tube number? I'm putting all the info into Post 11 then using that as a how to
Is an aluminum pan any better than a steel pan?
Aluminum is better depending on how you look at it.
When you want to change an oil pan gasket on steel, you have to raise the motor (without mangling the tinfoil steel they put on there), get the mount off, get the bracket off (no easy feat) then swap the pan gasket.
When you change the gasket on the aluminum pan, you use a block of wood and jack the pan up, pull the mount off with 3 easy to get at bolts and poof, the pan is ready to come off. This pan uses GM engine sealant instead of a gasket. Usually one and done.
You can jack the motor with the aluminum pan, steel you can't. It'll crumble like a bud can. it's less prone to leaking, it's structural, it'll never rust out.
