Thread: Freshly built and painted motor found threaded holes on sides of block? What r they?
Results 1 to 20 of 29
SleeperGS Freshly built and painted... 07-18-2012, 01:19 PM
PurpleGuy Re: Freshly built and painted... 07-18-2012, 01:21 PM
BillBoost37 Re: Freshly built and painted... 07-18-2012, 01:21 PM
BillBoost37 Re: Freshly built and painted... 07-18-2012, 01:23 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 01:25 PM
Rico Re: Freshly built and painted... 07-18-2012, 01:29 PM
BillBoost37 Re: Freshly built and painted... 07-18-2012, 01:33 PM
BillBoost37 Re: Freshly built and painted... 07-18-2012, 01:28 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 01:51 PM
Rico Re: Freshly built and painted... 07-18-2012, 01:53 PM
BillBoost37 Re: Freshly built and painted... 07-18-2012, 01:54 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 01:56 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 01:57 PM
Rico Re: Freshly built and painted... 07-18-2012, 01:57 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 02:16 PM
Rico Re: Freshly built and painted... 07-18-2012, 02:19 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 02:47 PM
Rico Re: Freshly built and painted... 07-18-2012, 02:52 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 02:55 PM
SleeperGS Re: Freshly built and painted... 07-18-2012, 03:00 PM
BillBoost37 Re: Freshly built and painted... 07-19-2012, 06:34 AM
Rico Re: Freshly built and painted... 07-18-2012, 11:42 PM
SleeperGS Re: Freshly built and painted... 07-19-2012, 06:17 AM
Rico Re: Freshly built and painted... 07-19-2012, 11:30 AM
blueguy Re: Freshly built and painted... 07-19-2012, 08:49 AM
lrscgod Re: Freshly built and painted... 07-19-2012, 08:58 AM
SleeperGS Re: Freshly built and painted... 07-25-2012, 12:53 PM
Rico Re: Freshly built and painted... 07-25-2012, 02:17 PM
SleeperGS Re: Freshly built and painted... 07-26-2012, 07:33 AM
  1. #1 Freshly built and painted motor found threaded holes on sides of block? What r they?
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    As the title states, just rebuilt and painted my motor...finally......anyways, puting tranny on and noticed 3 threaded holes on each side of the block by the knock sensors, what are they for??? I dont remember taking anything out of the old motor or seeing that these were missing? Looked on google and says something about 'girdle' bolts for the main caps???.. Pic inlcuded. Please help. Also i need a ported TB and have left messages for people to no avail. Main concern is these threaded bolt holes....looks like oil would leak.
    Pictures by KEVINDLITTLE - Photobucket
    As usual,
    Many thanks
    Kevin
  2. #2 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Never Never Land
    Not sure. But you can link the image to the forum. Just click on the very last link that appears when you drag the cursor over the pic.
  3. #3 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    To the left of the knock sensor is the AC bracket hole. for the rear bracket. To the right..I think stays empty.
    There are girdle bolts aka side bolts into the main bearings. but there's one in each bearing. So you'll see 4 of them on each side.
  4. #4 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
  5. #5 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    There are 3 on each side, not counting the a/c brackets...I think... You can see the main caps.....It appears like a 10mm bolt would fit there.....oone on each cylinder.....oil would have to leak...again, I think
  6. #6 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by SleeperGS View Post
    There are 3 main cap cross bolts on each side. Number 4 cap (next to flex plate) does not have these.
  7. #7 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    My pictures suck
    And then I find what I want.
    And yes on the three
  8. #8 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    If you can tell they are at the mains..then yes. There should be bolts in there. I remember them being about 10mm Lemme look for antoher pic.
  9. #9 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    are they an kind of special bolt? O ringed or anything to prevent oil from leaking? 3 of them per side right (6)?
  10. #10 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    There is sealant on the underside of the head and they are TTY bolts.
  11. #11 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    yes..3 per side..nothing special that I can remember. Those pics got some dust on them.
  12. #12 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    Pardon me for maybe asking the same question that may have been answered already but, I need 6 bolts.......perrmatex on all of them, what kind of thread and what size, and where the hell do i get them??
    Thanks
  13. #13 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    i just dont know how long they need to be, or if they need to touch on something on the insde.
  14. #14 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    GM dealer.
    They'll have the sealant already on them.
  15. #15 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    are they called main cap bolts?
  16. #16 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    Call your local GM parts counter or walk in. They'll know exactly what you're talking about.
    Tell them they're the 6 cross bolts for the main caps that have sealant on the threads and the head.
  17. #17 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    By the way... Do you like my color choice on the block?
  18. #18 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    Looks like Elvis' engine from the 70's.
  19. #19 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    Your actuallt not far off, color that is. I have a Regal ,not a GTP. Buick used a similar color gold engine paint in the 50's or 60's. Thought I would be different.
  20. #20 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    What do those bolts do? Keep the mains from coming loose or what?
  1. Ahhh...freshly painted dash
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 11-29-2009, 09:41 AM
