Thread: Have a feeling this is sposed to be plugged in someplace. Help Please!
Results 1 to 17 of 17
  1. #1 Have a feeling this is sposed to be plugged in someplace. Help Please!
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    So I was poking around in my engine bay last night and I came across this plug that wasnt connected. I have a feeling it is sposed to go somewhere but i couldnt seem to find where. Anyone know where its sposed to go to?!
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    St. Louis
    Judging by the location I'd say nothing. I have that plug on my 00 GT as well and nothing is connected to it, nor has it ever. Just for some option I don't have.
  3. #3 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Alright thank you. Thought maybe this was why my car was running a little bit different but I guess not. lol.
  4. #4 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Have you considered cleaning that oily mess?
  5. #5 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Florida
    I had the same plug on my old GT.I believe it is for an L67 MAP sensor.GM decided to let it be in some GTs but it helps if you plan to top swap, its just plug and play considering you buy the MAP extension harness.
  6. #6 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Quote Originally Posted by dmahlikGT View Post
    Map sensors are three wire. That's no map sensor. May have been the plug in for the Cali emissions soleniod.
  7. #7 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    I was actually attempting to degrease my engine bay so it was a bit wet when I had taken the pic. lol
  8. #8 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Florida
    Hmm its possible, but I know when i had an L67 MAP sensor the plug in my car plugged right into it perfectly.
  9. #9 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    The L36/L26 and L32 map sensor connector is all the same. A three wire with a purple seal (IIRC) around it for weather proofing. That connector he has is a two wire.
    Quincy, Mass
    that might be the evap solenoid but i think bill is right and went to one of the emission things that earlier models had
    No more GP 04 Impala SS Indy:
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Thats the connector to the EVAP vacuum switch. Here's a pic of mine
    Sent from my SGH-T679 using Tapatalk 2
  12. #12 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Annnnnt sorry Ride.. he's not a 97 like you are. Therefore he doesn't have a evap purge switch, only a single valve, which in his year is likely mounted on the front of the motor with a red two wire connector.
    You can tell some about his year by the engine cover bracket in the pic. He's newer. Likely an 02.
    Quincy, Mass
    Bill you know way too much lol. But I knew that already
    Jul 2012
    California
    When I grow up, I want to be as knowledgeable as you Bill.lol.
    Sent from my SGH-T679 using Tapatalky 2
  15. #15 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Quote Originally Posted by iRideGTP View Post
    Work on a lot of the same basic car. It also helps that I pulled a motor last night on a car with Cali emissions and the plug looks identical. My Bonne was a 97, that I 99 harnessed laster and found all the differences. Only years with the two evap pieces was 96 and 97 ... 96 the GP didn't get a 3800
  16. #16 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    Is there a difference between the 02 and 00?
  17. #17 Re: Have a feeling this is sposed to be plugged in someplace. Help Please!
    I've seen more 02'a with the cali emissions than other years..but sure that plug could be on any of them.
  1. Cooling system, feeling the heat..
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2011, 01:19 AM
  2. I think my AC drain is plugged ?
    By Y2KGTP in forum General Tech Discussion
    Last Post: 04-18-2011, 12:40 PM
  3. Intermittent flat tire feeling..
    By genocide in forum Brakes/Suspension/Chassis
    Last Post: 03-23-2011, 11:48 AM
  4. Feeling pretty anxious : )
    By AmericanRiceEater in forum Off Topic Discussion
    Last Post: 07-27-2010, 12:32 PM
  5. I have a feeling this can't be good..
    By mr2stig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2009, 11:21 AM
