Thread: What are symptoms of vapor lock
Results 1 to 7 of 7
  1. #1 What are symptoms of vapor lock
    Jun 2012
    spencer
    My car has had quite a few issues in the past couple weeks and I was wondering if vapor lock is the cause when it runs for a while it gets rough and when you try to start it it will surge and sometimes stall when I shut it off erlier today it steamed I don't know if it was rain from last night or something in the car please help any answer helps
  2. #2 Re: What are symptoms of vapor lock
    I've never heard of a gp getting vapor lock because the fp is in the tank to prevent it. What codes are you throwing?
  3. #3 Re: What are symptoms of vapor lock
    im willing to bet the check engine light is on.
    if it is, go get it scanned.
  4. #4 Re: What are symptoms of vapor lock
    SWPA
    You're not going to get vapor lock in a fuel injected vehicle. The fuel pump is much too strong to allow it.
  5. #5 Re: What are symptoms of vapor lock
    Feb 2010
    TN
    He's right
  6. #6 Re: What are symptoms of vapor lock
    Jun 2012
    spencer
    No codes ha it check a couple days ago there are no lights on
  7. #7 Re: What are symptoms of vapor lock
    Feb 2009
    flintnasty MI
    try removing the gas cap and see if that makes a difference.
  1. Symptoms like a clogged cat
    By Sig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2011, 06:30 PM
  2. Low Oil Pressure but no symptoms?
    By EJOUIE in forum General Tech Discussion
    Last Post: 06-09-2011, 09:10 PM
  3. Water vapor in exhaust after LIM gasket repair
    By Obrigado in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-26-2010, 08:12 AM
  4. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
  5. fuel vapor smell....
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 09-01-2008, 10:45 PM
