Thread: Freshly built and painted motor found threaded holes on sides of block? What r they?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    The main caps on this block are cross bolted! This makes an extremely strong and rigid block - cross bolting is typically only seen on extreme competition engines!
    Reference: L67 Engine Teardown - Thrasher Engineered Performance 3800 & 3800SC Pontiac Grand Prix GTP & Buick Regal GS
  2. #22 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    I bought some yesterday for 16.88, which I felt was reasonable for a dealer. I did not know about the cross bolting thing, learn
    Something new daily, thanks a mint!
  3. #23 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    I dunno how your motor was redone and those left out.
  4. #24 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Did that VHT gold for a guy here last year.
    We did the block, oil pan, and heads though.
    It was awesome.
  5. #25 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    The cross bolts essentially make it a 4 bolt main engine. Moar=Good in that case.
    4 out of 3 people have trouble with fractions
  6. #26 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by SleeperGS View Post
    There is a torque + angle spec for those TTY bolts you know.
  7. #27 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    still looking for the torque specs. I obviously took them out when i had it dipped and forgot. Never rebuilt one of these. That VHT paint is pretty good, im impressed with it.
  8. #28 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Apr 2009
    Fort Worth TX
    11 ft-lb + 45 degrees
  9. #29 Re: Freshly built and painted motor found threaded holes on sides of block? What r th
    Dec 2010
    Cincinnati, Ohio
    Put them in last night, thanks for all the help. Hope I can return the favor some day.
  1. Ahhh...freshly painted dash
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 11-29-2009, 09:41 AM
