Thread: Car makes humming noise when driving
Results 1 to 7 of 7
  1. #1 Car makes humming noise when driving
    Jul 2012
    West Seneca, NY
    I was driving my 07 Grand Prix earlier today. It had been raining out and I took a corner a little too fast. My brakes locked up and I ended up hitting the curb pretty hard but avoided hitting anything else (luckily).
    I left for work later and noticed that when I approach the 20mph mark, the car makes a very loud humming noise. Once I got on the highway and was going about 65, the noise quieted down considerably. And the noise stops completely when the car is stopped.
    Did I knock something loose when I hit the curb earlier? Is it a serious problem?
    Thanks for any help that you folks can give me.
  2. #2 Re: Car makes humming noise when driving
    chances are you killed the wheel bearing/hub assembly.
    also make sure your lower control arm is not bent, and tie rod are still good. <<<this would be the first place to look if your steering wheel is no longer straight.
  3. #3 Re: Car makes humming noise when driving
    Jul 2012
    West Seneca, NY
    I'm supposed to go out of town after my shift at work today. Is it safe to drive for a day or two or is this the kind of thing that should be repaired ASAP?
    "Old Soldiers never die; they just fade away." -General Douglas MacArthur
    R.I.P. PFC Dusty Seidel
  4. #4 Re: Car makes humming noise when driving
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    If this was due to normal wear and tear, you might be able to get away with it for a while before any of those parts get bad enough that they'd completely break on you/leave your vehicle inoperable. However, since this happened due to impact, I would definitely get it looked at to see how bad the damage is before making a long trip or driving 65mph again. You do NOT want a tie rod letting loose on you at those speeds.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  5. #5 Re: Car makes humming noise when driving
    if you can hear it, it should be fixed. i just did one on my car yesterday, took a whole 45 minutes to do. nothing real hard about it, if you can change your brakes you can change a hub. i say that because the brakes need to come off, completely off.
  6. #6 Re: Car makes humming noise when driving
    Jul 2012
    West Seneca, NY
    Okay. Thanks for the help guys, I really appreciate it
  7. #7 Re: Car makes humming noise when driving
    heres the how to. if you plan on doing it your self. i got a timken for 119.00 at auto zone friday night. dont buy a cheap o hub, unless you like to do jobs twice.
    http://www.grandprixforums.net/how-r...ubs-10985.html
  1. humming noise while driving
    By monfotrac in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2010, 12:28 PM
  2. humming noise
    By speed24 in forum General Tech Discussion
    Last Post: 07-01-2010, 02:25 PM
  3. humming sound while driving
    By foursixer in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2010, 03:42 PM
  4. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  5. new humming noise??!!??!!
    By Morris 04 GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2009, 09:33 AM
