Thread: Comp Cams Re-useable rocker bolts - torque spec?
Results 1 to 7 of 7
  1. #1 Comp Cams Re-useable rocker bolts - torque spec?
    Cambridge, Ontario Canada
    Is it 11 ft lbs + 90 degree OR 23 ft lbs straight up? How much thread locker & where to put on threads?
    Stock rockers if that matters.
    2005 E55 - stock
  2. #2 Re: Comp Cams Re-useable rocker bolts - torque spec?
    Mar 2012
    NC
    23 ft lbs...a bead of threadlocker starting about 3 threads from the end. Make sure the valves are closed just for piece of mind.
  3. #3 Re: Comp Cams Re-useable rocker bolts - torque spec?
    Quote Originally Posted by hitman92499 View Post
    How can I rotate the engine to make sure? Once I am able to rotate what is the best well to tell if they are closed?
    2005 E55 - stock
  4. #4 Re: Comp Cams Re-useable rocker bolts - torque spec?
    Mar 2012
    NC
    Put the rockers on hand tight and rotate the engine by the crank bolt with a 1/2" ratchet or breaker bar. When both rockers are down and wiggly then tighten them to spec.
  5. #5 Re: Comp Cams Re-useable rocker bolts - torque spec?
    As we discussed in other thread, don't really need to make sure they're closed.
    Also make sure the holes are dry and not filled with oil.
  6. #6 Re: Comp Cams Re-useable rocker bolts - torque spec?
    Mar 2012
    NC
    I know Matt, but like I said, it's for peace of mind. It's the way I've always done it and will continue to in the future just because I'm old skool like that.
  7. #7 Re: Comp Cams Re-useable rocker bolts - torque spec?
    I put q tips in the holes for a day or so & got all the crap out. I appreciate the piece of mind part for sure. I torqued them down to 23 and applied the thread locker from about thread three to thread eight. I also tried rotating the engine as well and I hear a lot of air/fluid sound in my opinion. I checked every single rocker and turning a bit just to be 200% sure.
    I also let the lifters bath in oil over night. I cleaned the pushrods them before re-install dipped each end in oil.
    2005 E55 - stock
  1. Comp cams 5/16" rocker bolts
    By tod1d in forum General Tech Discussion
    Last Post: 12-23-2011, 02:17 PM
  2. inner tie rod torque spec
    By jhnnyboz in forum General Tech Discussion
    Last Post: 08-08-2011, 09:01 PM
  3. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  4. COMP Cams 1.8:1
    By TMC in forum General Tech Discussion
    Last Post: 10-14-2008, 08:50 PM
