Thread: Center display not working
Results 1 to 8 of 8
  1. #1 Center display not working
    May 2008
    Which fuse controls the center display(oil life, range, etc...) in a 2000 GTP? Mine is currently blank and I want to make sure it's not a fuse before trying to replace it.
    Apologies if this has been asked before. My search skills failed me as I don't know what the center display is technically called.
    Thanks,
    Steve
  2. #2 Re: Center display not working
    It's the driver's information center DIC. Your bulbs are probably burnt out.
  3. #3 Re: Center display not working
    May 2008
    Thanks. Unfortunately, I tried replacing the bulbs and there was no change. The TCS and Low Trac lights still work, but nothing in the main section.
    I've been having issues with the ignition lock cylinder where it sometimes won't release the key except in the Acc or On positions. The air bag light between the speedo and tach has also come on with all these things happening
    Is it possible that the ignition switch is going bad?
    Thanks,
    Steve
  4. #4 Re: Center display not working
    It's possible. I'd swap it out and see if it fixes it.
  5. #5 Re: Center display not working
    May 2008
    Do I need to replace the lock cylinder at the same time?
  6. #6 Re: Center display not working
    Mar 2012
    NC
    No, the electrical part is its own unit.
  7. #7 Re: Center display not working
    May 2008
    I replaced the ignition switch this evening, and it fixed up my key issues. Unfortunately the DIC main display still doesn't work.
    I have now checked the DIC/HVAC fuse, replaced the bulbs, and replaced the ignition switch. Is there anything else that I could possibly need to do to fix it, or am I looking at having to replace the whole unit?
    Thanks
  8. #8 Re: Center display not working
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    just get one at the junkers just make sure its 98to 03 and has tcs instead of traC. I got one for $25 for my old se
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  1. Replies: 4
    Last Post: 01-20-2013, 09:54 PM
  2. No display on driver information center
    By sabarrett in forum General Tech Discussion
    Last Post: 02-17-2012, 11:58 PM
  3. 2006 Grand Prix Radio display half working
    By ffbwizard in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2011, 06:32 AM
  4. Radio Display Not Working
    By y1a3o in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 11:02 AM
  5. Center Display Help
    By Forrest in forum General Tech Discussion
    Last Post: 03-06-2009, 09:58 AM
