Thread: Ive almost had it with this car! 03 GT Limited Edition that I bought brand new
Results 1 to 3 of 3
  1. #1 Ive almost had it with this car! 03 GT Limited Edition that I bought brand new
    Virginia
    If it aint one thing its another, I've been living with the floating gas gage because I just don't have time to fix it. My Fix keep it full. Air conditioner hose has a leak, I can't figure out how to reach the couplings (damn front wheel drive). Did my pre state inspection check on it today, and now the washer fluid pump is burned out (will not pass inspection in Virginia). Did some research and I think theres no fuse for the pump just the wipers. Mabeye I should justtrade it in.
    O.K. I vented. Anybody know how to get to the Upper A/C hose on an 03 GT, and Am I correct that there is no fuse for the Washer fluid motor?
    David
  2. #2 Re: Ive almost had it with this car! 03 GT Limited Edition that I bought brand new
    Dave...I don't want to make it sound easy...but your issues are small and relatively easy.
    Which hose is the "upper"? I'm about to replace the piece with the orifice tube in my neighbors car. It's a serious pain to get at..but overall there's worse out there. Only have to move the master cylinder and abs, then scratch the hell out of your arms to do it.
    Fuse..there is definately a fuse for that pump. If it's not a fuse, it's not horrible to change the pump.
    Gas gauge.. I swear to you... I changed the level sensor on her car faster than she could change the headlights. That's right.. 4 10mm bolts took her longer than for me to swap the sensor in the tank. I was done in under 15 min.
    Grab some parts and tools...spend an afternoon with your car and you'll have all these items fixed up quickly.
  3. #3 Re: Ive almost had it with this car! 03 GT Limited Edition that I bought brand new
    Virginia
    I changed the washer fluid motor, took me all of an hour, and 30 minutes of that was driving to auto zone. Now im debating what to fix next, the gauge or the A/C..... probably the A/C since its only going to be in the 90's this weekend.
  1. Limited Edition GTP saying Hi
    By LEGTP03 in forum Introductions/Noob Questions
    Last Post: 12-01-2011, 06:23 AM
  2. 03 limited edition for sale.
    By justin1795 in forum Off Topic Discussion
    Last Post: 01-11-2011, 01:04 AM
