Thread: fuel pump
Results 1 to 6 of 6
  1. #1 fuel pump
    the desert
    Hi i was on here a couple months ago because of my fuel pump. While i was on here people were saying i only need the fuel pump which costs $30 and not the w
    hole canister. Does anyone know where i can get the part? thanks. 1999 pontiac grand prix gtp
  2. #2 Re: fuel pump
    GT Level Member sic6's Avatar
    san marcos, tx
    Your best bet is to get one from ebay or a local vendor on here. The auto parts stores will not sell just the pump,they will sell the whole fuel assembly. Thats were i bought mine.
    97 GTP
  3. #3 Re: fuel pump
    the desert
  4. #4 Re: fuel pump
    the desert
    How di i replace this piece?
  5. #5 Re: fuel pump
    Texas
    Quote Originally Posted by mcsddd View Post
    There's an access panel under the carpet in the trunk. It's in the middle closest to the passenger area. You can do the replacement in the back seat. Just food down the middle seat and go through the "window."
    Started fuel pump replacement. GM was kind enough to design an access panel in the trunk area. Removed the nuts holding it down and here is the module it's in. You can I had already started removing the lines:
    Clip was removed with a screwdriver:
    Pump and bucket dismantled:
    All back together and ready for reinstall:
    85 Corvette
    01 TA
    03 Z06
  6. #6 Re: fuel pump
    san marcos, tx
    No that is a mechanical pump. You want an electrical in tank pump that goes inside the canister.
    1998 - 2003 PONTIAC GRAND PRIX NEW ACDelco Fuel Pump | eBay
    97 GTP
  1. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
