Thread: seat heater
Results 1 to 5 of 5
whiteknuckle seat heater 09-07-2008, 11:37 PM
whiteknuckle Re: seat heater 09-11-2008, 10:25 PM
crimpton Re: seat heater 09-12-2008, 06:21 PM
whiteknuckle Re: seat heater 09-12-2008, 06:48 PM
webracin Re: seat heater 09-20-2008, 02:40 AM
  1. #1 seat heater
    Moore,OK
    does anyone have a schematic for the drivers seat heater in a 99?
    mine quit working a few days ago and with the colder months coming it sure would be nice if it worked. the switch lights up but the seat dosen't heat.
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  2. #2 Re: seat heater
    Moore,OK
    anyone?
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  3. #3 Re: seat heater
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Just because the switch is illuminated doesn't necessarily mean it's functional(pending on how it's wired). Check your fuse first.
    The wire should run up the seat post next to the console. Make sure it's still connected and test for volts.
    If there is power there you prolly have a seperation up in the seat or right on the other side of the connector.
    If nothing there, pull the switch out of the console and test to see if there is volts coming in and out of the switch.
    I'm just telling you the process in which I would take to try to solve the problem. I don't have a schematic.
  4. #4 Re: seat heater
    Moore,OK
    cool, thanks. i'll start there. does anyone know if the FSM contains wiring diagrams? i know some don't and you have to buy them seperate
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  5. #5 Re: seat heater
    GTX Level Member webracin's Avatar
    Arkansas
    Hope this helps
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  1. Heater/Def/AC
    By GTPluv in forum General Tech Discussion
    Last Post: 01-22-2011, 08:49 AM
  2. Heater Core
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 08:58 AM
  3. Help!!! My heater died and i live in maine!!
    Last Post: 12-29-2007, 05:43 PM
