Thread: Low Coolant Light - NOT COOL!
Results 1 to 7 of 7
  1. #1 Low Coolant Light - NOT COOL!
    SE Level Member LePrix's Avatar
    May 2011
    Ottawa, ON
    Second time this week I am getting the low coolant light (arrow pointing down in the coolant symbol) and now I am panicking. I checked oil, regular oil colour (unless I have turned colour blind now, but with my luck my problems don't end with my GP), coolant reserve is at the HOT mark after I turn her off and at COLD when I come back to the car and hour later.
    PS: Basically I made this thread so you guys can reassure me that I don't have a leaky LIM(yet, because it is inevitable). Please tell me what I want to hear but don't protect me from the truth!
  2. #2 Re: Low Coolant Light - NOT COOL!
    coolant level sensor is dirty.
    you should do a coolant flush and replace the coolant.
    Also good idea to do a pressure test, but if you never have to add any, its not leaking.
  3. #3 Re: Low Coolant Light - NOT COOL!
    May 2011
    Ottawa, ON
    matt, call me an uber n00b but how do I flush the coolant,(should I on my own driveway?) and how to conduct a pressure test. I only know of the way where I drive it to a shop and say "take my money".
  4. #4 Re: Low Coolant Light - NOT COOL!
    You can skip the test because your coolant levels aren't getting mysteriously lower.
    Flush is drain system, fill with water and some additive that says rad flush or rad super clean on it, then run for a couple days then drain and fill back up with coolant.
    Or drain and use rad flush tee that installs in heater hose. I suggest buying a foot of 5/8ths heater hose so you dont have to cut your factory lines. Those hookup to the garden hose and will push all of the coolant out and leave behind water.
    You'd typically fill it back up with full strength coolant then check with a coolant strength tester to make sure you have the right mixture. at least 50% coolant, but no more than 60 or 70%.
    Easier method would be pay shop. They'll pressure flush the system with new coolant.
  5. #5 Re: Low Coolant Light - NOT COOL!
    May 2011
    Ottawa, ON
    matt, I have a seemingly unrelated issue but since you mentioned "heater core" i figured that might be it. I have gotten sloshing sounds every now and then from behind the dash, everyone here screamed "air in heater core". Could this be related?
    And god bless you for typing all that but I will take it to the shop.
  6. #6 Re: Low Coolant Light - NOT COOL!
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Yes i had a constant "low level coolant" light on when indeed my coolant wasnt low, took it off and cleaned it up a bit the light hasnt been on since.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  7. #7 Re: Low Coolant Light - NOT COOL!
    May 2011
    Ottawa, ON
    BUT Nixon has just confirmed with me that the substance known as DEXCOOL smells like dirty gym socks....the EXACT smell that permeates throught my interior fan....PLUS I hear sloshing...
  1. 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:51 PM
  2. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  3. "half" light tinting expiriment. looks cool. check it out.
    By colindunn in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
