Thread: Exhaust Build Questions-before i buy
Results 1 to 20 of 21
  1. #1 Exhaust Build Questions-before i buy
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have a 99 GTP i need to do headers and my stock cat back is toast, rusted and cracked same with the stock mufflers so i was wondering is this a good headers build list and will this cat back bolt up to these headers:
    headers
    Pontiac Performance Racing Products for International Sales from SSAutochrome Inc.
    Easy Performance - O2 Emulator #EP-O2SM-GM01
    Easy Performance - O2 Extension Harness #EP-O2EXHN
    ZZPerformance - O2 Sensor #
    Exhaust Band Clamp X2
    and will this cat back just bolt up?
    ZZPerformance - 2.5" Aluminized Catback Exhaust #ZZ-25GPALCB
    is there anything im missing? i know bill has a good write up that ill be using just wondering everyones thoughts
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: Exhaust Build Questions-before i buy
    glass pack for a res.
  3. #3 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    right i would just pick that up from a local parts store but does everything else look good?
  4. #4 Re: Exhaust Build Questions-before i buy
    May 2012
    Burlington, Wisconsin
    Are you actually going to need the extension and O2 sensor to install the headers? I have a 98 and am wondering if I will need those same parts with my headers.
    Stock o2 sensor location sucks.
    Move it into the crossover.
  6. #6 Re: Exhaust Build Questions-before i buy
    Quote Originally Posted by Btownmills View Post
    Yes, if you leave it in the same spot on the SSAC and SD headers. You could make one, buy I'd rather buy one and know it works.
  7. #7 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    i agree with FFDP about the harness and as for the o2 its self mine is bad so i figure id kill 2 birds with one stone and replace it when i do the headers guys i dont wanna sound rude but does this look like everything? and (if anyone knows) will that cat back bolt right up like are the flanges the same size and the lengths correct?
  8. #8 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    bump
  9. #9 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    anyone else have an opinion on this?
  10. #10 Re: Exhaust Build Questions-before i buy
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Don't use Blowmasters!!! LOL I have a new downpipe, Magnaflow cat, Ubend delete, res delete, two Flowmaster 40's... I could tell a difference in performance AND sound... I am debating on putting Magnaflow's on inplace of the flow's but I might just put on some turbo's to quiten it down a lil. I have heard that there are not many performance gains removing the stock mufflers for something else. I do love how my car sounds at idle, but through about 2500 RPM it's raspy, but cruising it's mellowed out so much the rumble puts my fiancee and kids to sleep.. LOL Just my $.02...
  11. #11 Re: Exhaust Build Questions-before i buy
    I had to change my shift points so it would never let the engine spin at less than 1800 otherwise the drone is overbearing.
    This is with the full magnaflow catback.
    Do I regret this purchase? 100%
  12. #12 Re: Exhaust Build Questions-before i buy
    Nov 2009
    Tennessee
    I know right!!!!!
    So plan B. I'll go with a set of turbo's or find some decent stockers... HA HA I'll go with turbos or maxi muffler specials.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  13. #13 Re: Exhaust Build Questions-before i buy
    Catback also drowns out the 3.4 pulley at WOT.
    Need less pulley.
  14. #14 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    im not so much focased on the sound just do i have all the pieces to do the build?
    Youll need gaskets and rtv.
  16. #16 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    i plan on reusing he stock gaskets and rtv will melt
  17. #17 Re: Exhaust Build Questions-before i buy
    Jan 2012
    Philadelphia
    copper RTV
  18. #18 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    is that what you used ive heard some mixed reviews
  19. #19 Re: Exhaust Build Questions-before i buy
    Jan 2012
    Philadelphia
    no i dont have headers yet, im just saying i dont think copper RTV is going to melt easily
  20. #20 Re: Exhaust Build Questions-before i buy
    Oct 2011
    Michigan
    idk the people at belle tire said not to use that and i know its just belle tire but if they would use it im not so sure i would
  1. Exhaust questions..
    By TheManInBlack in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2011, 02:43 PM
  2. Exhaust questions
    By Jsmith309 in forum General Tech Discussion
    Last Post: 09-02-2011, 10:20 PM
  3. Exhaust questions
    By Javi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2011, 07:04 PM
  4. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  5. JL CleanSweep Install Questions. Ultimate stock SQ build.
    By poormanjoe in forum Audio, Security & Visual Electronics
    Last Post: 08-05-2010, 01:08 PM
