Thread: no shift indicator light
Results 1 to 13 of 13
  1. #1 no shift indicator light
    Apr 2012
    Windsor
    Hey,
    I bought a 2005 grand prix gtp comp-g a few months ago and finally noticed i have no up shift indicator light when in manual mode. It does not show up on the HUD or dash or DIC. Ive tried turning the HUD off to see if it would show up than but nothing. Is this a feature that might of been turned off by the previous owner?
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    It comes on at pretty high rpm.
  3. #3 Re: no shift indicator light
    dont use manual mode.
  4. #4 Re: no shift indicator light
    Apr 2012
    Windsor
    why?
    And i have gone up to 4000rpm in first gear, So it should of showed up by then
  5. #5 Re: no shift indicator light
    Stock shift point is well under 6,000 rpms. More so around 5400-5500.
  6. #6 Re: no shift indicator light
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    you can go higher the 4k man just keep it under 6k to keep you motor safe
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  7. #7 Re: no shift indicator light
    Jan 2012
    Philadelphia
    Quote Originally Posted by asite57 View Post
    im pretty sure it will shift before it redlines even if it is in 1st gear, i know my car did. i dont use manual shift i just tried it out before for the hell of it, i have performance shift so thats good enough for mr lol. as for the light goes i never even knew there was one. maybe thats for the 04+ models or comp g's im not sure
  8. #8 Re: no shift indicator light
    Its an auto? lol
    Thats my opinion. The car is always faster is D.
  9. #9 Re: no shift indicator light
    Oct 2011
    Michigan
    manual mode isnt for speed its to make you wish you actually had a manual
  10. #10 Re: no shift indicator light
    Yoga city
    uhm well my gxp doesnt have any shift lights i know of besides the indicator in the dic and hud.
    Dec 2011
    Grand rapids Mi
    I'll check to see where it comes on today.
  12. #12 Re: no shift indicator light
    Apr 2012
    Windsor
    Yes its an auto, it has tapshift. I dont use manual to drive i just use it to mess around now and then. I read this in the manual and thats when i realized ive never seen a shift indicator.
    "The up-shift indicator light
    on the instrument panel
    cluster, or the up-shift
    symbol on the Head-Up
    Display (HUD), if equipped,
    is given as a prompt to
    use the TAP-Shift ™
    paddle.
    The up-shift indicator light will only appear in the
    instrument panel cluster if the HUD is off or if the
    vehicle does not have HUD.
    This prompt to up-shift, as needed, will be given
    throughout acceleration. If up-shifting does not occur
    when prompted, the vehicle speed will be limited
    to protect the engine."
    I know i can rev higher than 4k in first gear but thats not the point. Im just wondering why i dont have a shift indicator light on in the HUD or dash.
    Dec 2011
    Grand rapids Mi
    Mine comes on at 4500 rpm but it only comes on if the HUD is turned off.
  1. shift indicator light in cluster not working after gtp trans swap
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2012, 02:43 PM
  2. Fog light switch indicator bulb
    By SnowDrift in forum General Tech Discussion
    Last Post: 11-16-2011, 10:20 AM
  3. how to change shift indicator light?
    By nwulf1 in forum General Tech Discussion
    Last Post: 02-17-2011, 03:04 AM
  4. Oil change light indicator
    By sasquatch094 in forum General Tech Discussion
    Last Post: 09-06-2009, 09:20 AM
  5. High Beam Indicator light stays on
    By mike4567 in forum General Tech Discussion
    Last Post: 08-07-2009, 08:05 PM
