Thread: No AC or Heat with 2002 Grand Prix
Results 1 to 6 of 6
  1. #1 No AC or Heat with 2002 Grand Prix
    Jun 2012
    Edmonton
    Hey Guys. I have been searching the Internet to try to help with my Grand Prix. Started last week. No AC or Heat at all, fan doesnt turn on. I looked online and it seems like this is a common problem with a resistor if fan settings level 5 works but the others do not. None of the fan settings work at all so I figured it was the blower motor itself. Bought a new one and put it in today and still same issue. Anyone know what this could be? I hear a click near the blower motor when I turn the fan on from level 4 to 5 but it seems to only make the sound when at level 5.
  2. #2 Re: No AC or Heat with 2002 Grand Prix
    St. Louis
    Have you checked all your fuses?
  3. #3 Re: No AC or Heat with 2002 Grand Prix
    Could be a bad resistor still but i'm not sure that it would entirely go bad like that.
  4. #4 Re: No AC or Heat with 2002 Grand Prix
    Jun 2012
    Edmonton
    Hey guys checked all the fuses and they all look fine
    I am thinking resistor too but having none of the settings work is worrysome.
  5. #5 Re: No AC or Heat with 2002 Grand Prix
    Check the voltage at the resistor and see if you have 12v before it. If you do then the resistor is bad.
  6. #6 Re: No AC or Heat with 2002 Grand Prix
    Sep 2011
    Sherman Texas
    If it has the Auto Climate Control its probably the control module and maybe part of the wiring harness going to it... Look for my other post I made earlier and it has some parts you can replace...If it is Auto Climate you do not have the resistor btw just the control module..
  1. 06' Grand Prix heat not hot...
    By tdub36tjt in forum General Tech Discussion
    Last Post: 10-26-2012, 07:45 AM
  2. 98 Grand Prix GTP Heat/AC/Air control
    By xsvtank in forum General Tech Discussion
    Last Post: 05-10-2010, 07:18 PM
  3. 98 Grand Prix no heat
    By 71dang in forum Introductions/Noob Questions
    Last Post: 10-25-2009, 04:09 PM
  4. 98 Grand Prix GT too much heat NO AC
    By markh in forum General Tech Discussion
    Last Post: 09-25-2008, 10:29 PM
