Thread: Rear Wheel Hub Compatibility Question
Results 1 to 5 of 5
  1. #1 Rear Wheel Hub Compatibility Question
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Quick question.
    Are the rear wheel hubs for a 2004 GT1 without ABS the same as the hubs with ABS. Yes, I know one has the ABS sensor and the other does not. But I was wondering if you can use the ABS hub?
    Reason being is I can get a good deal on a set of ABS hubs (New) For the same price as a single non ABS hub. Yes I know, it doesn't make sense to me either. The ABS hubs should be more expensive.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  2. #2 Re: Rear Wheel Hub Compatibility Question
    exactly the same.
    Does your gp have no abs?
  3. #3 Re: Rear Wheel Hub Compatibility Question
    they should work, just cut the plug and wire off or tuck it in all nice somewhere.
  4. #4 Re: Rear Wheel Hub Compatibility Question
    Apr 2012
    Wilbraham MA
    exactly the same.
    Yes, I have a 2004 GT1. No ABS at all. I've had several occasions where I've had to lock it up on the highway that I travel every day. It's not fun. LOL
    I just want to make sure they would physically fit in the carrier. Pretty sure that they will.
  5. #5 Re: Rear Wheel Hub Compatibility Question
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Yes, they will. the only advice I have is to make sure to get good SKF brand hubs, otherwise you will be re-doing the same job in under 20k miles.
  1. Steering wheel and after market head unit compatibility question
    By CRASHMAN55 in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2012, 05:23 AM
  2. Rear Wheel drive
    By Whitehispanic in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2011, 08:55 AM
  3. "rear" wheel hub replacement question
    By 03GPGTOWNER in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2010, 10:39 PM
  4. Rear Wheel Conversion
    By whyspyder in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2009, 08:55 AM
  5. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
