Thread: Code P0401. Insufficient EGR Flow. Bad MAP sensor right?
Results 1 to 5 of 5
  1. #1 Code P0401. Insufficient EGR Flow. Bad MAP sensor right?
    Jun 2012
    Iowa
    Had a code pop up yesterday while driving and when I got it checked it was p0401 which basically means that the egr isnt flowing enough. I did an hour or two of searching on the site and the web and most people say that if thats the only code(which it is) that its the map sensor. Im just wondering if anyone else had the same problem and if a new map actually fixed it.
  2. #2 Re: Code P0401. Insufficient EGR Flow. Bad MAP sensor right?
    I'd start by taking the EGR off and cleaning it out, then clearing the code and see if it comes back.
  3. #3 Re: Code P0401. Insufficient EGR Flow. Bad MAP sensor right?
    Jun 2012
    Iowa
    What do you suggest cleaning it with? Parts cleaner?
  4. #4 Re: Code P0401. Insufficient EGR Flow. Bad MAP sensor right?
    Brake cleaner, parts cleaner.
  5. #5 Re: Code P0401. Insufficient EGR Flow. Bad MAP sensor right?
    Jun 2012
    Iowa
    Ok, I was looking at the metal-type hoses coming off of it should I bother with those?
  1. p0401 code
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2012, 11:22 AM
  2. P0401 code now...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2011, 02:21 PM
  3. P0401 Code
    By screechingdemon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2011, 09:24 AM
  4. code P0401
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 01:30 PM
  5. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
