Thread: DIY Meth injection ?'s
Results 1 to 5 of 5
  1. #1 DIY Meth injection ?'s
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i have searched and only found sparratic info on this. i have heard of people taping your intake and running your windshield washer nozzles into your lower intake manifold, and using the washer switch to spray at WOT.
    pro's and con's of this?
    if it is really legit, what position and where on the LIM would you tap and run the nozzles?
    i have also been told you dont have to run a tune for it.
    how does this work? it just cools the cylinders and keeps knock down at 0? do you tune to actually get power out of meth injection
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: DIY Meth injection ?'s
    I don't think the nozzles would work well post blower. you'd have that extra ~10 PSI fighting the nozzles/pump.
  3. #3 Re: DIY Meth injection ?'s
    Mar 2012
    NC
    Washer nozzles don't have pressure enough or proper spray pattern. Meth injection typically uses a higher pressure and sprays a very fine mist into the intake.
  4. #4 Re: DIY Meth injection ?'s
    Texas
    Local had his setup through the LIM. Worked well for him.
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: DIY Meth injection ?'s
    Mar 2012
    Dallas
    Quote Originally Posted by hitman92499 View Post
    so i would have to get a high pressure pump and nozzles to make it work.
    what about tuning?
  1. Well I done did it guys.(Meth Injection)
    By ChrisJ in forum General Tech Discussion
    Last Post: 04-19-2009, 10:58 AM
