Thread: A/C Leaking into passenger compartment?
Results 1 to 13 of 13
  1. #1 A/C Leaking into passenger compartment?
    Apr 2012
    USA
    First off I'll post a little backstory in case it trips any red flags.
    2000 Grand Prix GT
    My blower is only working on 5. Any other setting is the same as 'off'. I'm told this is a bad blower motor resistor. I'm fixing this in the future, it doesn't really bother me now.
    Never had any issue with the A/C in the 6 years I've owned the car, never recharged it, never died on me.
    Present poblem:
    Occasinally I am hearing a squealing whule the A/C runs, hard left banking *seems* to cause it, it usually fades out in 10s or so. Aside from the noise causing me to wonder wtf is going on, I'm not bothered by it.
    Yesterday, after running A/C for approx. 20 minutes, there was significant condensation leaking into the passenger compartment, dead center between where your legs go.
    On top of this, I notice the driver side vents are not blowing nearly as cold as the passenger side. Driver side seems somewhat cool, but passenger side is nice and chilly.
    My best guess(and where I hope you can provide some feedback):
    In talking to a few people, they said they had similar issues(with one side blowing cooler than the other) and they fixed it by adding a can of refridgerant(spelling? Lol). The $7 cans, not the "one you use when its completely dead".
    Other things suggested for the same issue with blowing cooler on one side is "the flapper is not closing completely". Vague understanding of this.
    As far as the condensation coming in, all I have heard is that "[possibly] my heater core is shot".
    Thoughts? Similar issues? Any feedback is appreciated, and please keep in mind I have varying levels of understanding of different engine components, so I would appreciate a dumbed down explanation if its not too much trouble. Thanks for reading this.
  2. #2 Re: A/C Leaking into passenger compartment?
    yes fan only on setting 5 only is the resister.
    take your belts off and spin all of your pulleys see if you can find a bad one. your compressor clutch maybe also be on its way out.
    warm on the d/s can be low refrigerate or a bad blend door actuator.
    the wetness, touch it. is it sticky as it drys? if so its coolant. pull the carpet up and see if you can trace it. if you noticed the wet floor after a good rain it could be the cowl heres a link to that repair....http://www.grandprixforums.net/water...-fix-6961.html
    did i miss anything? lol
  3. #3 Re: A/C Leaking into passenger compartment?
    Yup, you did. lol
    Moisture on the floor when not sticky is sometimes condensation from the evap core. You'll want to unplug the drain for the heater box. Likely junk got in where the permanant fix sits and has clogged the box drain. I would fix that before looking into why you don't have good ac on the driverside as they may be related. Aka .. the water in the box may be blocking the duct.
  4. #4 Re: A/C Leaking into passenger compartment?
    he did have a long list in my defense......
  5. #5 Re: A/C Leaking into passenger compartment?
    Apr 2012
    USA
    Also also, I have never had any moisture in the car after a rain or otherwise, but thanks for the suggestion and the link
  6. #6 Re: A/C Leaking into passenger compartment?
    Apr 2012
    USA
    I appreciate the replies.
    My first step is(based on the replies) to unplug the drain from the heater box and check/clean junk that may be blocking it?
    Also next time I'm at my parents I will be adding refridgerant because he has all the stuff I need to do this.
    I am confused by one thing " take your belts off and spin all of your pulleys see if you can find a bad one. your compressor clutch maybe also be on its way out."
    Which issue is this looking to address?
    Thanks a lot to both of you for the replies as well, its appreciated and I will keep you posted and you have my thanks.
    The moisture is not sticky and has no odor to it and is clear(best I could tell) so leads me to believe it's condensation
  7. #7 Re: A/C Leaking into passenger compartment?
    Apr 2012
    USA
    Quote Originally Posted by Korben View Post
    Posting/replying on my phone and it's good about misplacing my cursor, that last line should have been further up in the reply somewhere, lol
  8. #8 Re: A/C Leaking into passenger compartment?
    that would be addressing the squealing when banking hard left turns. the clutch goes bad on the a/c and will make a real racket when going bad. dont know what turning has to do with it but squealing is usually the belts for some reason or another. bad pulleys. idlers and tensioners most of the time.
  9. #9 Re: A/C Leaking into passenger compartment?
    is just one of the most common reasons the pass side floor gets wet.
  10. #10 Re: A/C Leaking into passenger compartment?
    Apr 2012
    USA
    Just doing some general browsing brought me here
    http://www.grandprixforums.net/heater-core-64498.html
    It was also mentioned this could be an issue?
  11. #11 Re: A/C Leaking into passenger compartment?
    come to think of it, i had a leak but not so much inside the car, but it was fogging up my wind shield, so i pulled my heater core. yeah thats fun, and it was dry and not leaking, i hooked it up out side the car and ran the hoses to it.
    turned out my heater core hose was bad in the end, and leaking into the car a bit, and dripping to the ground, dead center of the car at the fire wall.
  12. #12 Re: A/C Leaking into passenger compartment?
    None of your symptoms point to a heater core from what I read. Hey..I'm gonna go get a breakfast sandwich.
  13. #13 Re: A/C Leaking into passenger compartment?
    Apr 2012
    USA
    Well that's good. Tomorrow I'm gonna try just filling the refridgerant. That'll be step 1 in hopefully a short-stepped solution. Wish me luck.
  1. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  2. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
  3. Replies: 15
    Last Post: 09-19-2010, 09:53 AM
  4. Battery Compartment Mount
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-08-2008, 05:37 PM
  5. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
