Alright so threw some new parts on the car. Specifically:
Shift Kit
new zzp hub + pulley + new zzp coupler
Poly Mounts
The car was running without a supercharger belt for a while since the pulley decided it didn't like it's life and broke off. So finally got the new hub, installed it, put the 3.4 on, put new oil in and fired her up. Initially the car was running great while parked. I was wot it via the cable to see if anything was wrong and it sounded fine. Took it for a test drive and wot through a gear and all of a sudden, the car starts sputtering. We stop in a parking lot to evaluate, and we couldn't find the culprit. All the vac lines looked fine, and everything was connected, but it was sputtering and struggling to stay on and the filter was sucking in a lot of air. No CEL's either..
Anyways, got the suggestion to leave the cars battery unplugged over night to reset the pcm to recognize there is a supercharger back in the mix (maybe messing up the fuel trims, who knows). Come to start it the next day, it turns on and then dies right away. Even if I give it some gas to keep it alive, it'll die when the RPM's come back down. So got another suggestion that it might be the MAF sensor so decided to look into it. Unplugged the MAF and the car runs fine, idles high which is normal with an unplugged MAF, but it runs.
So took some MAF cleaner to it and let it dry. Checked the rest of the TB and everything looked fine, filter looked good, the screen looked okay, nothing inside to clog it.. So plug the cleaned MAF back in, and the car does the same thing, it starts, revs high and then dies. Tried a couple of times, and it would not stay on. To test, I unplugged the MAF, started it, and then tried it plugged in and it wielded the same results over and over. Car runs with MAF unplugged but without it plugged in. So conclusion is that MAF is bad right?..
Wrong, I take the MAF out of my brothers 02 GT and try it out, same exact story. Would not stay running at all, but unplugged it ran fine. Then decided to try the MAF on the 2000 Daytona my brother just drove home (mind you both the 02 and 00 run fine). His MAF kept the car on but it wanted to die and it was struggling to stay on the whole time. We got a CEL when the MAF's were unplugged and it was for the MAF, but nothing else popped up..
So.. yea what could be the possible problems?? The car is sitting in my driveway all day and I have a day off, so I wanna try some things out and see if I can't get it running again today.. I don't like driving my parents cars.. they're slow lol But seriously, thanks to anyone that contributes!!
