Thread: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
Results 1 to 12 of 12
Brian1975 Help - Electrical Ac/ Heat... 07-07-2012, 07:15 AM
Sven the Sexman Re: Help - Electrical Ac/... 07-07-2012, 07:27 AM
Brian1975 Re: Help - Electrical Ac/... 07-07-2012, 07:53 AM
Swiggles If its not the fuse then it... 07-07-2012, 07:52 AM
Brian1975 Re: Help - Electrical Ac/... 07-07-2012, 07:58 AM
Brian1975 Re: Help - Electrical Ac/... 07-07-2012, 07:59 AM
dsmuts Re: Help - Electrical Ac/... 07-07-2012, 07:56 AM
Brian1975 Re: Help - Electrical Ac/... 07-07-2012, 08:00 AM
Sven the Sexman Re: Help - Electrical Ac/... 07-07-2012, 07:58 AM
Swiggles If it is a fuse for that it... 07-07-2012, 08:09 AM
Brian1975 Re: Help - Electrical Ac/... 07-15-2012, 04:01 PM
  1. #1 Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    Hello all,
    I am new to this forum and would really appreciate your help before I pay someone a ton of money to fix a potentially easy problem.
    The issues:
    Ac/ Heat do not work unless the switch is on the highest setting. My digital diagnostic display is out (the diagram of the car which shows a door open and also gives you your mpg, distance to empty etc.) and my day time running lights are out.
    I saw online the ac and heat issue could be the blower resister but would this also be affecting the lights and electrical? It all happened at once.
    If you know what may be wrong, is this something I could fix myself? I am not a mechanic and the extent of my experience is switching out an alternator and basic maintenance.
    Thank you so much in advance
    Sincerely,
    Brian
  2. #2 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Mar 2012
    NC
    Check fuse 29 in the underhood fuse panel.
  3. #3 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    Quote Originally Posted by hitman92499 View Post
    Thanks for the suggestion, Fuse 29 looks good
    Quincy, Mass
    If its not the fuse then it just be a coincidence that it happened at the same time. The bulbs in the back of the dic (mpg stuff is called the drivers info center of dic) are these I'm pretty sure, there's 3 for the screen http://www.amazon.com/ACDelco-PC168-...lco+light+bulb
    If those aren't the right size then I think these are http://www.amazon.com/ACDelco-PC74-B...lco+light+bulb
    No more GP 04 Impala SS Indy:
  5. #5 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    Thanks, I will look into this.
  6. #6 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    Quote Originally Posted by Swiggles View Post
    If those aren't the right size then I think these are Amazon.com: ACDelco PC74 Bulb: Automotive
    Thanks, I appreciate it
  7. #7 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    If the blower only works on high then your resistor is probably bad. Where are you from in oh?
  8. #8 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    I am in the Warren area.
  9. #9 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    I have been sinking a ton of money into this thing lately, only has about 60K on it and very clean so I don't want to get rid of it but its like one thing after another.
  10. #10 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Mar 2012
    NC
    Well, in that case, check all the fuses first. Chance that it's a coincidence seems unlikely, but it IS a Grand Prix so these things could happen. Don't forget about the fuses in the glove box area.
    Quincy, Mass
    If it is a fuse for that it would likely be the one the one in the glove box but think its also the radio fuse just can't remember.
  12. #12 Re: Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    Jul 2012
    Ohio
    Hello All,
    I discovered something additional about this issue. When the car starts up the drivers information center works just fine, I do notice that when the fan speed is at zero the headlights work, then the intervals until high phase out the headlights and then they come back on again on high fan speed.
    Any clues?
  1. No AC or Heat with 2002 Grand Prix
    By supeg in forum General Tech Discussion
    Last Post: 06-29-2012, 10:53 PM
  2. 2001 grand prix 3800 heat issues. HELP PLEASE
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 06:47 PM
  3. 2000 Grand Prix Electrical issues
    By Stappen720 in forum General Tech Discussion
    Last Post: 09-24-2009, 06:32 AM
  4. 2002 Grand Prix Gt issues, need some expert advice
    By gtpx02 in forum General Tech Discussion
    Last Post: 06-10-2009, 11:19 PM
