Thread: Problems with the HEATER CORE???
Results 1 to 3 of 3
  1. #1 Problems with the HEATER CORE???
    Jul 2012
    I am having problems with my 04 Grand Prix...go figure. So couple days ago i noticed a weird smell like antifreeze or something in my car didnt think much of it. Also, I noticed my air was not as cold as it usually is. Well yesterday on my way to work my car started rumbling at a stop and I looked down and my engine light came on and my computer said "Shutting off air to protect engine". My temp gauge was past the red and smoke started pouring in through my air vents all on the INSIDE of the car. Pulled over let car sit and then checked Antifreeze to find it was bone dry. Took to friends work down the street let sit all day then put more antifreeze in only to find that it started leaking drip drip drip from two places under my glove box. So...everyone has been telling me its my heater core. Could it be anything else?? If not and it is my heater core I have heard it is hard to replace on this car. Like 400$ labor!? Which I am not into. Can it be done by someone just following directions or should I have it taken to a shop? Also is there any way to get around replacing it like bypassing the firewall and just have my heater not work for a while?? ANY suggestions and help would be much appreciated thanks!!!
  2. #2 Re: Problems with the HEATER CORE???
    St. Louis
    Sounds like the core to me if it's getting inside. You could bypass it for now. All you really need to do is remove the center console, lay on the floor and locate all the small screws that hold the airbox together and there you go. Once you pop the airbox open the core will be visible.
  3. #3 Re: Problems with the HEATER CORE???
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Definitely sounds like the heater core.
    To check everything else out.
    1. Locate the 2 heater hoses on the firewall and remove them from the nipples.
    2. Follow the hoses to the back of the engine by the alterator and remove one hose from the outlet.
    3. Put the remaining hose back on the outlet. You have now made a loop and bypassed the heater core.
    4. Fill system up with coolant and bleed system. Let it run and come up to operating temps and check for any other leaks or damage.
    5. Good Luck
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  1. heater core
    By pontiaclemon in forum General Tech Discussion
    Last Post: 07-11-2012, 12:00 PM
  2. heater core
    By gtpinsc in forum General Tech Discussion
    Last Post: 04-01-2011, 12:29 PM
  3. heater core
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 10:24 PM
  4. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  5. heater core?
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2009, 02:16 PM
