Thread: Repairing wire to driver's front seat belt buckle?
Results 1 to 2 of 2
  1. #1 Repairing wire to driver's front seat belt buckle?
    Dec 2011
    Cliffside Park, NJ
    I believe this wire goes to the driver's seat belt buckle and signals that the driver's seat belt is buckled. (There is no longer a chime or flashing seat belt light on the dash when I turn the ignition on.) Any ideas on how I should go about repairing it?
    Many thanks, Joe
    1998 GTP Sedan
  2. #2 Re: Repairing wire to driver's front seat belt buckle?
    chances are its from the seat belt. i would remove the seat, 2 bolts on the floor, back side of the seat on the floor, and see where they went.
    with any luck one wire has a strip on it, match it back up if there are any wires left to re splice too.
    if not you may need a new seat belt lock with the wire.
    it should plug in under the seat on the center rail. with another plug, could be 3 if you have side air bags,(that would be the yellow plug) heated seat and a power seat plugs.
  1. driver side seat belt guide broken
    By Larry N in forum General Tech Discussion
    Last Post: 05-31-2015, 12:05 PM
  2. Driver side rear seat belt won't retract.
    By David Stewart in forum General Tech Discussion
    Last Post: 03-26-2012, 06:55 PM
