Thread: Failed Emissions Inspection (1st try)
Results 1 to 20 of 26
  1. #1 Failed Emissions Inspection (1st try)
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Ok , so I went to get my car (2005 Pontiac Grand Prix) inspected so I could renew my tags. The guy connects his OBD connector and prints out a form and tells me that my o2 sensor, cat , and evap system are Not Ready. Basically I didnt pass. Ok so I need help locating the problem , I was told that I need to do a Drive Cycle. The problem im having is that the check engine light has turned on about 3 times now, everytime it is a P0420 which basically it is a CAT problem. I turn off the light with my OBD2 connector. I have speed daddy headers, hi flo cat (could be the problem) . Any help will be appreciated I need to get the parts I need to fix the problem and also I need to do a Drive Cycle.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  2. #2 Re: Failed Emissions Inspection (1st try)
    The PCM needs to run the OBD diagnostics.
    Which then result in a fail of one of the tests.
    Depends on the rules for your region.
    Here one fail of any test is a fail. Only one system can read not ready in order to pass.
    What you need is a quality cat and to let the PCM run its diagnostics.
    Buy a magnaflow 43009 cat and have it welded in.
  3. #3 Re: Failed Emissions Inspection (1st try)
    May 2012
    Santa Cruz, Ca
    P0420 IS A CAT EFFICENCY BELOW THRESHOLD. The pcm monitors the front and rear 02 sensors to monitor the converter. Basically if the rear o2 sensor starts to sweep .1v to .9v the converter is not storing oxygen and isn't working at its full potential. The rear o2 sensor should be a flat line if looking at it on a scope. Replace your cat and drive it. Good luck
  4. #4 Re: Failed Emissions Inspection (1st try)
    Houston
    Every time that you clear that code, it resets the monitors. And you have to do another drive cycle. My hi flow cat caused that fault but it is now tuned out of my pcm. The Catalyst will never show ready, but I can have 1 monitor show "not ready"
  5. #5 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    Ok if I buy the CAT, then have it welded do I still need to do a Drive Cycle ?? By saying " let the PCM run its diagnostics" how does the PCm know how to do that?
  6. #6 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    I have an Intense PCM and I didnt delete the cat. I believe all the codes need to show READY in AZ
  7. #7 Re: Failed Emissions Inspection (1st try)
    Yes.
    You can google the GM drive cycle. Follow that procedure to complete those tests quicker.
  8. #8 Re: Failed Emissions Inspection (1st try)
    Houston
    I didnt delete the CAT, just the P0420 code. It doesnt trip the SES light, or show up on the test equipment that they connect to your car. I just went through this the last few years. Took me 2 years to finally get it to pass. I had two monitors showing not ready. The EGR and CAT. I reinstalled an EGR system and once it finished its diagnostics, it showed ready. But if you have to have all monitors show "ready", you may need to reinstall a stock CAT.
    Buffalo
    Then you didn't set the DTC correctly
  10. #10 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    Yes.
    ok so you recommend that magnaflow cat? I was told that the hi flo cat was probably the one throwing the code.
  11. #11 Re: Failed Emissions Inspection (1st try)
    Houston
    This is from Arizonas emissions website
    Model year 2001 and newer vehicles
    may not have more than one “not-ready” monitor.
  12. #12 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    k I have a summit account which CAT is recommended to install , I believe the headers are 3"? Any suggestions, also im also replacing the o2 sensor as well what part# do I need .
  13. #13 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    Ok well I had 3 NOT READY . Evap System , o2sensor and CAT
  14. #14 Re: Failed Emissions Inspection (1st try)
    Houston
    Ah, the EVAP is the one that took me the longest to pick up. My 02 sensor picked up pretty quickly though.
  15. #15 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    Should I order this cat MagnaFlow 99009HM, also what is the part# for the rear o2 sensor?
  16. #16 Re: Failed Emissions Inspection (1st try)
    Quote Originally Posted by compgjoe2793 View Post
    no that one isn't that good.
    order the 43009.
  17. #17 Re: Failed Emissions Inspection (1st try)
    Jan 2009
    order the 43009.
    Cant find the 43009 on Summit anything similar?
  18. #18 Re: Failed Emissions Inspection (1st try)
    Can't you space out the rear o2 with washers so it doesn't throw the code? I thought I read that somewhere but could be mistaken.
  19. #19 Re: Failed Emissions Inspection (1st try)
    GT Level Member Utter99's Avatar
    Warsaw indiana
    dsmuts i believe is talking about this... kind of interesting to see if itll work for you rather than going the rout you are already.... just an option
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
    GTP Level Member apierce1289's Avatar
    United States
    Why even bother? Why not get a pcm from overkillwill? If you just need to pass the obd2 computer test. Tell him your issue and your mods then get a new O2 sensor and fix the evap. Point being... Get the stupid catalytic converter codes tuned out and never worry again. I run an Overkill tune and straight pipes to just mufflers. Btw I pass every time lmao :-P
    Sent from my Droid Razr using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. Passing Inspection
    By apierce1289 in forum The Rant Forum
    Last Post: 08-11-2012, 05:21 AM
  3. Passing inspection!
    By apierce1289 in forum PCM Tuning
    Last Post: 04-06-2012, 01:44 PM
  4. i passed inspection
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 06-17-2011, 09:50 AM
  5. inspection problem
    By kingd44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2011, 08:17 PM
