Thread: Failed Emissions Inspection (1st try)
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Failed Emissions Inspection (1st try)
    Joe...
    You are in Chandler I see. Hop on AZGMPerformance.com or is it GMAZPerformance.com and find PDXGTP, aka a local GP guy in Chandler. He should be able to fix this up quickly. Thomas is a good guy who will know exactly what you need to do to the pcm to pass.
    Since you have an 05, it's highly unlikely any Magnaflow is going to cure the code. Most high flows don't meet the specs the pcm is looking for.
    Here's 97-03 drive cycle. May also be the same for you.
    http://www.grandprixforums.net/how-r...cle-50998.html
  2. #22 Re: Failed Emissions Inspection (1st try)
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Joe...
    Thanx Bill!
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #23 Re: Failed Emissions Inspection (1st try)
    NP, glad to help.
    SE Level Member smcglaug18's Avatar
    Arizona
    Hey bill, just stumbled upon this thread and it sounds like you're the go-to guy. I'm throwing the same code p0420 and am hesitant to change out my cat and o2 sensors because it was just done 4 years ago. I've got emissions as well and need some advice. Totally broke right now too . Anybody out there in car land have suggestions?
    Thanks in advance.
    Sent from my LS670 using Tapatalk 2
    GTP Level Member apierce1289's Avatar
    United States
    Why even bother with the stupid tree hugger codes when they can be tuned out? All it takes is a little bit of research to find these answers. Anybody that has hp tuners software would be able to set these codes to "no error reported" I just looked at this stuff today in my hp tuners (in my tune file). So I know it's there lol :-P
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  6. #26 Re: Failed Emissions Inspection (1st try)
    SMC.. in the bar above each post is a number. Take a look at post #21. Should have everything you need to get straightened up. Tell Thomas I said hi.
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. Passing Inspection
    By apierce1289 in forum The Rant Forum
    Last Post: 08-11-2012, 05:21 AM
  3. Passing inspection!
    By apierce1289 in forum PCM Tuning
    Last Post: 04-06-2012, 01:44 PM
  4. i passed inspection
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 06-17-2011, 09:50 AM
  5. inspection problem
    By kingd44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2011, 08:17 PM
