Thread: Dynamat Knock Sensor Kit question
Results 1 to 16 of 16
  1. #1 Dynamat Knock Sensor Kit question
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    So I recently picked up this kit from Intense because I think I have false knock and I was planning on replacing my knock sensor's anyway so I thought I would give it a try. Anyway, I was just wondering where the bigger piece goes on the trans? I don't have to remove the trans do I?
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Dynamat Knock Sensor Kit question
    it goes dead center. one min.. got a pic
  3. #3 Re: Dynamat Knock Sensor Kit question
    Put it there...if you dare
  4. #4 Re: Dynamat Knock Sensor Kit question
    Apr 2013
    Milwaukee
    Oh snap, I would have to remove the engine? Lol
    Sent from my PantechP8010 using Tapatalk
  5. #5 Re: Dynamat Knock Sensor Kit question
    you can kinda get in there. take pass side front wheel off have some one push it up in place brom the bottom, then rub it down from the side.
    you may need some sticks to press it in fully. paint stir stick something like that.
  6. #6 Re: Dynamat Knock Sensor Kit question
    Apr 2013
    Milwaukee
    Ok thanks
  7. #7 Re: Dynamat Knock Sensor Kit question
    oh, and clean the living crap out of it the day before if you've had oil leaks, trannys get real nasty right in the spot bill posted.
    when i de grease my engine i always turn the wheels left then from the wheel well spray the tranny down, front and back as much as you can. if you have ramps spray it from underneath too.
  8. #8 Re: Dynamat Knock Sensor Kit question
    Apr 2013
    Milwaukee
    Ok, ya I'm sure I'll have a mess down there.
  9. #9 Re: Dynamat Knock Sensor Kit question
    I'd rather pull the motor.
  10. #10 Re: Dynamat Knock Sensor Kit question
    Apr 2013
    Milwaukee
    Not worth it just to apply that Imo.
  11. #11 Re: Dynamat Knock Sensor Kit question
    You are correct...it's not worth anything to apply that there. The trans is bolted to the engine all around that spot. If there's noise getting through the casing..there's noise transmitting through the bracketry
  12. #12 Re: Dynamat Knock Sensor Kit question
    Apr 2013
    Milwaukee
    Well I got my front knock sensor installed but I have no idea how ppl can get to the rear one without removing the trans. It's such a tight fit! How is it possible!?
  13. #13 Re: Dynamat Knock Sensor Kit question
    deep socket, long extension, long needle nose pliers to un plug and plug it back in. its been done before, you can do it!
  14. #14 Re: Dynamat Knock Sensor Kit question
    A bit of magic, a bath and plenty of swearing...I'd imagine.
  15. #15 Re: Dynamat Knock Sensor Kit question
    glendale guy got it done.
  16. #16 Re: Dynamat Knock Sensor Kit question
    glendayle is a Regal driver... this guy has a GP. Everything is infinitely harder on a gp
  1. knock sensor question...
    By scottgs03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2013, 05:39 AM
  2. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  3. EGR and knock sensor question
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-25-2012, 06:31 AM
  4. knock sensor
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-09-2011, 06:52 AM
  5. Front Knock Sensor Removal Question
    By nickbuol in forum General Tech Discussion
    Last Post: 07-23-2009, 08:22 AM
