Thread: The EGR code that doesn't want to go away
Results 1 to 20 of 22
  1. #1 The EGR code that doesn't want to go away
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I've had the code for about 4 months now, and every time it seems to go away, it comes right back.
    Things i've tried:
    -Replaced EGR valve
    -Fixed all exhaust leaks
    -Fixed all vacuum leaks
    -Changed all leaky gaskets
    -Tried another pcm
    -Got new valve flex hoses (one had a crack in it, thought this would finally do it) The voltage numbers on the scanner are good too.
    But then after driving for about 20 minutes, it came back on but then shut off 20 minutes later. I must be getting close right? Does anyone know what i'm missing?
  2. #2 Re: The EGR code that doesn't want to go away
    I know what's missing. And I likely know that everything that's been done so far couldn't have fixed the issue.
    You say.. Bill, how's that possible w/o me even listing the code? You're right. Please list the code and the name behind it. Cause I might be wrong with it being P1406 EGR Insufficient Flow.
    Edit.. code should be p0401
  3. #3 Re: The EGR code that doesn't want to go away
    Mar 2012
    NC
    OOOOH! OOOH! Can I list the cause?
  4. #4 Re: The EGR code that doesn't want to go away
    Please.. cause it's at the opposite end from the EGR.
  5. #5 Re: The EGR code that doesn't want to go away
    Oct 2011
    New Jersey
    It was P0401 if i remember correctly. And the flow through all of it is fine as i know of? The car also runs and idles beautifully so you guys should tell me whats wrong so i can go fix this
  6. #6 Re: The EGR code that doesn't want to go away
    My wifes bonneville kept throwing an egr code i can't think of which one right now but i pulled the old egr off my parts car and it worked fine. She had a brand new egr on there before i threw the old one on to fix it.
  7. #7 Re: The EGR code that doesn't want to go away
    Mar 2012
    NC
    The council says MAP sensor. LOL
    The MAP is my 3rd choice...there are other checks I'd do as well. Such as make sure your EGR port is clear of carbon bulld-up in the manifold and watch the front O2 sensor switching in case it got lazy and isn't reading the O2 change when the EGR opens. After that, MAP!
  8. #8 Re: The EGR code that doesn't want to go away
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    My CEL is on for an EGR. I will just have the code shut off when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    when I get it tuned
    If ever.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  9. #9 Re: The EGR code that doesn't want to go away
    Crap..I had my code mixed up. P0401 Insufficent flow. Which I mentioned the flow part.
    Ok, go to Gearchatter.com and search P0401, now read the diagnostic aids. What it'll say to you is the EGR flow is measured by the MAP sensor. If the map sensor isn't reporting seeing the change, you get a code that has EGR in the title. Once you research it, you'll see that it's almost never an EGR that needs to be swapped. It's likely the map sensor or wiring to it.
  10. #10 Re: The EGR code that doesn't want to go away
    gardner,mass
    delete egr problem fixed
    no but same problem i had replaced egr replaced map and replaced both egr pipes (they both were cracked) and it finnally went away, please tell me you looked inside where the pipes go for solid carbon
  11. #11 Re: The EGR code that doesn't want to go away
    Oct 2011
    New Jersey
    I'll definitely have to look around the MAF then. I know there is no carbon buildup in and around the EGR due to checking everything multiple times. I'm guessing it might be the MAF since that is the only thing i haven't laid a finger on yet. Thanks guys i'll keep you updated.
  12. #12 Re: The EGR code that doesn't want to go away
    map not maf
  13. #13 Re: The EGR code that doesn't want to go away
    Mar 2012
    NC
    MAP...MAP...MAPlol
  14. #14 Re: The EGR code that doesn't want to go away
    gardner,mass
    Quote Originally Posted by GTLGDP View Post
    buy some maf cleaner, but i dought its that cus car wouldnt run right, we said the MAP
  15. #15 Re: The EGR code that doesn't want to go away
    PS, Please do what I suggested. You will learn a lot quickly and have it fixed up in no time.
  16. #16 Re: The EGR code that doesn't want to go away
    gardner,mass
    also i got my map from the jyard for like 15 bucks the egr for 25 and the hoses i got from dealer one for 40 other for 55
    even that getting the **** from jyard not all new your better off just ordering a pretuned pcm for 120 and getting some blockoff plates for 5
  17. #17 Re: The EGR code that doesn't want to go away
    Is the map the same for a na and sc?
  18. #18 Re: The EGR code that doesn't want to go away
    Mar 2012
    NC
    No, the MAP is different between the two.
  19. #19 Re: The EGR code that doesn't want to go away
    No, totally different. It's in teh pcv cap of the NA
  20. #20 Re: The EGR code that doesn't want to go away
    gardner,mass
    no its not
    you can look up other 3800 s/c though like regal bonni impala
  1. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  2. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  3. Doesn't heat
    By crimson red in forum General Tech Discussion
    Last Post: 11-01-2011, 11:19 PM
  4. This doesn't look right???
    By donkason in forum General Tech Discussion
    Last Post: 05-13-2011, 08:05 PM
  5. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
