Thread: OBDII Sensor not Working
Results 1 to 9 of 9
barbschwartzer OBDII Sensor not Working 05-30-2012, 08:38 PM
Fivefingerdeathpunch Re: OBDII Sensor not Working 05-30-2012, 08:45 PM
barbschwartzer Re: OBDII Sensor not Working 05-30-2012, 08:46 PM
Fivefingerdeathpunch Re: OBDII Sensor not Working 05-30-2012, 08:48 PM
barbschwartzer Re: OBDII Sensor not Working 05-30-2012, 08:50 PM
BillBoost37 Re: OBDII Sensor not Working 05-31-2012, 06:29 AM
barbschwartzer Re: OBDII Sensor not Working 05-31-2012, 06:32 AM
BillBoost37 Re: OBDII Sensor not Working 05-31-2012, 06:43 AM
barbschwartzer Re: OBDII Sensor not Working 05-31-2012, 09:12 AM
  1. #1 OBDII Sensor not Working
    Apr 2011
    Ohio
    Hi guys. I just got my OBDII reader in the mail today, and was eager to test it out. I plugged it in to my 2003 GT's OBDII port and . . . nothing. The lights on the unit didn't even light up. To check if I had just bought a knockoff Chinese piece of garbage, I tried it out on our '04 Silverado and my brother's '02 GTP. It worked like a charm both times. My research thus far has brought me to the conclusion that I have either a faulty fuse (the cig lighter one, perhaps?) or some ignition switch problem. I'm trying to find a fuse diagram and part online, and am not having any luck. Anybody had this problem? Any suggestions?
  2. #2 Re: OBDII Sensor not Working
    open the glove box and pull the thing that covers the fuses, it should have a diagram of where each fuse is.
    Then see if the cig light fuse it out.
  3. #3 Re: OBDII Sensor not Working
    Apr 2011
    Ohio
    It's in the glove compartment fuse box, not the under-hood?
  4. #4 Re: OBDII Sensor not Working
    yes, a bunch of fuses are there.
  5. #5 Re: OBDII Sensor not Working
    Apr 2011
    Ohio
    Is that fuse for both cig lighters, or just the one right below the radio? And am I correct that that's also the one that controls power to the OBD port?
  6. #6 Re: OBDII Sensor not Working
    Yes...that's what you found in your research and that's what FFDP confirmed for you. Most likely when you check it, you'll find it's bad.
    Hope that helps
  7. #7 Re: OBDII Sensor not Working
    Apr 2011
    Ohio
    Thanks, guys. Very helpful. I'll pull swap that fuse and post the outcome.
  8. #8 Re: OBDII Sensor not Working
    good luck, hope it's that easy.
  9. #9 Re: OBDII Sensor not Working
    Apr 2011
    Ohio
    Worked like a charm. That fuse was burnt to a crisp. Thanks again for your help.
  1. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  2. low light sensor not working
    By jrocthakidd in forum Audio, Security & Visual Electronics
    Last Post: 05-08-2011, 03:29 PM
  3. Obdii?
    By Viper in forum General Tech Discussion
    Last Post: 03-06-2010, 09:58 AM
