Thread: throttle bodies-whats the best bang for the buck?
Results 1 to 11 of 11
  1. #1 throttle bodies-whats the best bang for the buck?
    racine,wis
    can someone tell me which is the best choice as far as what tb to go with.(my blower is not ported). and my mods are below. thanks
    s1x cam-wbs headers-intense shift kit-intense pcm-cai-zzp 3.25.
  2. #2 Re: throttle bodies-whats the best bang for the buck?
    Ported stocker, ported blower/LIM, re-tune the PCM.
  3. #3 Re: throttle bodies-whats the best bang for the buck?
    I'm a fan of the N*. It's bolt on, toss new maf table in and go.
  4. #4 Re: throttle bodies-whats the best bang for the buck?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    X2 on that.
  5. #5 Re: throttle bodies-whats the best bang for the buck?
    Grand Island, Nebraska
    Bang for the buck, ported stocker is probably better since all you need is a dremel and JB weld. The N* is bigger though, and you'll need a MAF tune either way.
  6. #6 Re: throttle bodies-whats the best bang for the buck?
    The max theoretical flow of a 68 mil TB is 550-600 cfm or so.
    Thats what a gen V with a 3.4 will pull in.
    So anything past that, larger throttle blade.
  7. #7 Re: throttle bodies-whats the best bang for the buck?
    Which is like a 3.1-3.2" on a GenIII blower...hence why I say...ported stocker.
  8. #8 Re: throttle bodies-whats the best bang for the buck?
    Eh, I've never seen any evidence to suggest the gen III is that much worse, or how much better a gen V is or how porting a gen III affects it.
    Vendors won't share either.
    Lets use GPF math.
  9. #9 Re: throttle bodies-whats the best bang for the buck?
    On that Matt, the best I can do is give you some unscientific messing around I've done. I ported the hell out of a Gen 3, smoothed and you name it. It helped, really did. Didn't compare with a Gen V though.
    Tempwise the Gen V was about 100F cooler than a Gen 3 on the same run. Obviously different engines, both cars run the same though. Even if the airflow is the same (M90 to M90) the cooler charge should make up the difference.
  10. #10 Re: throttle bodies-whats the best bang for the buck?
    Lets use GPF math.
    Like Bill said, you can't even begin to compare a GenV to a fully ported GenIII.
    Get to researching, research man.
    You'll see what I mean.
  11. #11 Re: throttle bodies-whats the best bang for the buck?
    Today is injector day.
    Perhaps later.
  1. Bang for the buck!
    By JunkBird69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2011, 12:01 AM
  2. Best bang for buck?
    By Edagimo in forum Engine
    Last Post: 06-16-2010, 09:22 PM
  3. Throttle Bodies ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 11:03 AM
  4. Desktop video card: Best bang for the buck?
    By BackInBlack in forum Off Topic Discussion
    Last Post: 11-12-2008, 10:11 PM
  5. Best Bang for your buck on speakers?
    By RichCresci in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2008, 04:49 PM
