Thread: Max AC blows heat on drivers side only
Results 1 to 3 of 3
  1. #1 Max AC blows heat on drivers side only
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    1997 Grandprix GT, dial controls, non dual climate control. Turn the selector gauge to Max AC, and the other all the way to cold, we are getting heat out of the drivers side vents, and cool air out of the passenger side vents. Is there a specific mixer door that is prone to failure or sticking?
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  2. #2 Re: Max AC blows heat on drivers side only
    Topeka, KS
    Probably a blend door actuator. Under the drivers side. It's kinda a beetch to get to unless you pull the drivers seat.
  3. #3 Re: Max AC blows heat on drivers side only
    Sep 2011
    Chicago
    I had the same problem with my 2002 Grand Prix GT. After reading many posts saying it could be the blend door control or low charge I looked under the driver side dash and located the blend door control near the center, a little hard to see, about the size of a pack of playing cards. i had someone move the driver side temp control and I could see the center of the control turn which indicated the controller was wooking. I then took the car to a shop where the pulled a vacuum on the system and checked for leaks. none were found. they charged the sysytem and it has been blowing 35 degrees for the last three weeks.
    Good luck,
    KAKMACK
  1. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  2. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  3. cant control where heat blows to
    By sheffy in forum General Tech Discussion
    Last Post: 01-03-2011, 08:17 PM
  4. Ac blows cold on one side but not the other?
    By 97whitegt in forum General Tech Discussion
    Last Post: 06-11-2010, 02:15 PM
  5. My heat only BLOWs on WINDshield?
    By nateberry in forum General Tech Discussion
    Last Post: 02-10-2010, 05:04 PM
