Thread: Just bought GTP and wondering
Results 1 to 6 of 6
  1. #1 Just bought GTP and wondering
    May 2012
    Where winter never ends
    I just bought a 2004 GTP with 75k miles on it. What should I do right away, or check right away to it to make sure it lasts its longest?
  2. #2 Re: Just bought GTP and wondering
    Plugs, wires (stock replacements)
    Oil change.
    transmission pan drop and filter change, new fluid.
    PCV valve.
    Air filter
    Take the TB off and clean it along with the MAF sensor, use the right cleaners.
    CHeck over the condition of suspension parts and driveline parts. Wheel bearings, ti rods, brakes etc etc.
  3. #3 Re: Just bought GTP and wondering
    GTP Level Member buickman104's Avatar
    NYC
    depending on mileage check LIM gaskets.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Just bought GTP and wondering
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    do a fuel filter also
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  5. #5 Re: Just bought GTP and wondering
    Sep 2011
    Copperas Cove, TEXAS
    Change the SC oil also.
  6. #6 Re: Just bought GTP and wondering
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i'm pretty sure that the 04 come stock with the bad LIM Gaskets. they didnt start the 2nd design till 05. someone please correct me if i'm wrong. if it is the 1st design, you DEF need to check the gaskets. here something that might help
    http://www.grandprixforums.net/how-t...ets-62678.html
  1. Just wondering if.......
    By chancinit666 in forum Tires & Wheels
    Last Post: 06-06-2010, 12:29 AM
  2. just wondering
    By chuy09 in forum Audio, Security & Visual Electronics
    Last Post: 08-10-2009, 10:32 PM
  3. Just wondering
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2009, 10:51 AM
  4. Just wondering?
    By The Machine in forum Track Sessions and Kills
    Last Post: 03-19-2009, 01:18 PM
  5. Just wondering
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 12-23-2007, 12:31 AM
