Thread: question about retainers
Results 1 to 6 of 6
  1. #1 question about retainers
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    Just installed the s1x cam, also put in 105lb springs. Can I use stock retainers with the 105's??
  2. #2 Re: question about retainers
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    VSS-105 Specifications:
    • Installed load is 105 pounds at 1.800", 127 pounds at 1.720", and 293 pounds at 1.200".
    • Coil bind height is 1.125".
    • Outside diameter is 1.290"/1.060" and inside diameter is .885"/.656".
    • Maximum lift supported @ 1.72 (stock retainer install height) - .595"
    • Maximum lift supported @ 1.80 (Manley retainer install height) - .675”
    It's a CUMMINS Dodge not a Dodge Cummins
  3. #3 Re: question about retainers
    Dec 2010
    Cincinnati, Ohio
    so is that a yes or a no....lol
    No. Lsx springs need lsx retainers.
  5. #5 Re: question about retainers
    Apr 2009
    Fort Worth TX
    I'm assuming you have the blower cam?
    This is on Intense web site:
    The Stage 1X Cam is the IDEAL aftermarket cam for use with stock heads, lifters, rocker arms, retainers, and pushrods. Aftermarket lifters, pushrods, and retainers are not necessary at this level, but there are certain reliability and performance gains to be had by replacing these items during your cam change. We always recommend and/or install 105# valvesprings with this camshaft. The powerband is strong from 2,600 to 6,600 RPM. With the supportive induction and exhaust mods in place, you should be able to run a 3.0" supercharger pulley with no intercooler when using this cam . Or, you could run a 3.25" supercharger pulley and increase your timing advance. The Stage 1X cam is designed to max out the stock cylinder heads, both in terms of air flow and also with regard to valvespring retainer to valve seal/guide clearance. Customers should check all necessary clearances especially if upgrading to aftermarket valve seals. The Stage 1X cam also works very well with a small shot of nitrous oxide (25-100 horsepower shots)
    Hope this helps.
  6. #6 Re: question about retainers
    Dec 2010
    Cincinnati, Ohio
    Yes, its the,blower sx1 cam
  1. S1x cam..what retainers?? (l76 springs??)
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 11:14 AM
  2. Springs and Retainers
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2010, 05:43 PM
  3. What type of retainers do I have?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2008, 04:16 PM
