Thread: Power steering leak??
Results 1 to 5 of 5
  1. #1 Power steering leak??
    Dec 2011
    Grand Prairie, Tx
    I got a small power steering leak on my car. Are there any known spots for the power steering to leak on these cars? Looks like it's been leaking for a while because i checked under the car and the passenger side underbody is caked pretty good with gunk buildup from the power steering
  2. #2 Re: Power steering leak??
    St. Louis
    Yea, they're known to leak at the pump, the rack, and the pressure line. Take your pick. Best bet would be to clean all the gunk off and then see if you can figure out where it's coming from.
    You can throw some Lucas power steering stop leak in there to try and help stop it. I got about a year and a half out of mine that way before the rack let go, which on mine was what was leaking in the first place.
  3. #3 Re: Power steering leak??
    SE Level Member DCGTP's Avatar
    Charleston SC
    Use some break parts cleaner to dry it all up from top to bottom from the pump down the line and the rack boots. test drive it for a few minutes and crawl back under to see if you get any better an idea. Mine has been leaking a while everything was wet, replaced the pump and the sender line, still no fix. if the boots are leaking its leaning towards a bad rack... ive got 101k on mine
    Overkilled, AL605s, 180 T-stat, Cone Intake, Cross drilled & Slotted Rotors, f-body upgrade, poly upper mounts, shorter dog bones,
    factory nav, 2x12s in the trunk, interior LED swap, all 5000k HIDs, red halo's in upper grille, tinted tails and reverse lights, de-badged, XM to line in conversion
  4. #4 Re: Power steering leak??
    Mar 2012
    Virginia
    Mine started leaking slowly, gotten really bad over the past couple of months. I've got a 2001, 242K miles, and this is the first real problem. Looks to be a bad rack - leaking closer to the driver's side where the boot is.
  5. #5 Re: Power steering leak??
    Charleston SC
    it might not be a bad rack, its likely a cracked line but at 242k who knows. mine was a cracked line and it made the gear box and driver side boot wet.
  1. Power steering leak
    By napes65 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2011, 11:20 AM
  2. Power steering leak
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2011, 07:13 PM
  3. Power Steering Leak
    By trailshredder in forum General Tech Discussion
    Last Post: 12-23-2010, 11:12 AM
  4. Power Steering leak
    By jokyfo in forum General Tech Discussion
    Last Post: 10-30-2010, 12:37 AM
  5. Power Steering fluid leak--Where?
    Last Post: 10-06-2008, 05:17 AM
