Thread: False knock causing p0327?
Results 1 to 11 of 11
  1. #1 False knock causing p0327?
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    I have a 2002 Impala LS that I'm trying to get inspected in NY. It's throwing 2 codes, a P0135 and a P0327. I'm going to replace the oxygen sensor for the P0135, but I don't know how to diagnose and repair a P0327. This car is very high mileage and has a pretty major exhaust leak and the manifolds leak alittle when they're cold. I'm wondering if this could cause enough false knock to confuse the PCM into throwing a P0327?
    Ohio
    Or the knock sensor is bad???
    Could be a short in the wiring.
  3. #3 Re: False knock causing p0327?
    Dec 2011
    Herkimer, NY
    Where is the knock sensor located? How do I determine if its bad?
    Ohio
    How do you know it's false knock?
  5. #5 Re: False knock causing p0327?
    Dec 2011
    Herkimer, NY
    I don't know it's false knock. I'm trying to eliminate the idea of loud exhaust leaks/leaky manifolds causing false knock enough for the PCM to set a P0327. I am asking if that's something that is possible, or if it is definetly the knock sensor/wiring.
  6. #6 Re: False knock causing p0327?
    Apr 2009
    Fort Worth TX
    On both sides of the engine under the manifolds.
  7. #7 Re: False knock causing p0327?
    Dec 2011
    Herkimer, NY
    Thank you. Does anyone know if there is a procedure to test the sensor with a multimeter?
    Bank 1 sensor 1 would be the front of the engine I'm hoping?
    Ohio
    Nope. Between the oil pan and tranny is the one that will be bad. When you pull it... You will get drenched in coolant.
  9. #9 Re: False knock causing p0327?
    Dec 2011
    Herkimer, NY
    Great! It couldn't be the easier one.
  10. #10 Re: False knock causing p0327?
    Apr 2009
    Fort Worth TX
  11. #11 Re: False knock causing p0327?
    Dec 2011
    Herkimer, NY
    Thank you.
  1. P0137, P0327 codes question
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-16-2011, 03:38 PM
  2. False knock??
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2011, 04:43 PM
  3. False Knock?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2011, 11:14 PM
  4. false knock?
    Last Post: 08-20-2009, 09:21 PM
  5. Need Help with p0327 and p0332
    By midblue00 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 08:22 AM
