Thread: transmission fluid
Results 1 to 4 of 4
  1. #1 transmission fluid
    Apr 2012
    Windsor
    I have a question about transmission fluid, Yes i have searched the forum but have not found what i was looking for. Im changing the transmission fluid and filter on my 2005 grand prix comp-g. It was changed 2 years ago at a shop by the previous owner and the receipt says it was filled using dexron iii. I picked up Mobil 1 dexron-VI ATF, Will there be any issues mixing the two since i wont get all the fluid out with just a filter change. Also is Mobil 1 dexron-VI ATF a good fluid to use for this transmission? i have read conflicting statements. Thanks
  2. #2 Re: transmission fluid
    There should be no mixing issues at all. GM recommends Dex 6 for all transmissions these days, it should not have trouble and shoudl be backwards compatible.
    With that said, I did dex 6 on my latest trans in an 2000 Regal. It is working well. As for Mobil vs other brands this should not make much of a difference either.
  3. #3 Re: transmission fluid
    Apr 2012
    Windsor
    Great thanks. Also I know the transmission's are different between the base model and gtp but are the filters the same? And how much fluid do I replace in a pan drop? 8qts? So 7.5 liters?
  4. #4 Re: transmission fluid
    Filter is the same for all the 4T60E and 4T65E models. It'll be the same filter. If you hit Advance it's Proking number FK-190.
    it'll take anywhere from 6.5 to 7.5 quarts.
  1. Replacing All of Your Transmission Fluid
    By stuzman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2011, 08:52 PM
  2. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  3. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  4. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
