Thread: Flex plate holes don't lineup
Results 1 to 4 of 4
  1. #1 Flex plate holes don't lineup
    May 2012
    Santa Cruz, Ca
    So I got this car with all the mods done...including a hole in #5 piston. I swapped out the motor and the torque converter bolt holes done lineup with the converter. I have looked and can't find any info here. The original flex plate had hogged out holes to remedy this so thats what I did. Any insight would be helpful
  2. #2 Re: Flex plate holes don't lineup
    Apr 2009
    Fort Worth TX
    What motor?: L67, L32, L36, L26
    What transmission? 4T65E, 4T65E-HD
    For some years I think the L67 had a slightly different torque convertor compared to the L36.
    Yes, some people just increase the hole diameter.
  3. #3 Re: Flex plate holes don't lineup
    Portland Oregon
    L67/32 = 258mm converter bolt circle
    L36/26 = 245mm torque converter bolt circle
    4T65E-HD = 258mm converter
    4T65E = 245mm converter
  4. #4 Re: Flex plate holes don't lineup
    Here's what you had
    Here's what you wanted
    Reason behind this is that the previous owner put a smaller torque coverter into the transmission. This is done because it's less rotating mass and the engine can rev faster. I've hogged/egged a couple when it was necessary. Rather put the correct flex plate on though.
  1. flex plate problems
    By butch2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 07:08 PM
  2. Flex plate upgrade
    By rodman in forum Turbo
    Last Post: 12-12-2009, 12:25 AM
  3. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
